Question about Hunter 52" Ceiling Fan With Light And Remote Control
I am trying to remove a remote from a hunter fan and change to manual. There is a black wire with a white stripe coming from the fan to the remote red (light out) wire. Which wire does this attach to in the ceiling?? The black or white wire???
    Genius:
  • Hunter Master
  • 1,617 Answers
That is your light wire. Attach to black wire if you have a light.
Posted on May 15, 2014
SOURCE: Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Posted on Jun 15, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
jmeredith
  • 417 Answers
SOURCE: Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Posted on Aug 06, 2008
  • 7 Answers
SOURCE: I am trying to install a new wireless hampton bay in a hunter
you need to get the right remote for the right fan....or it will never work correctly.
Posted on Feb 27, 2010
SOURCE: Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the g
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Posted on Feb 26, 2012
Trying to replace a remote controller in a Hunter ceiling fan with a Harbor Breeze univer. need help with wire color code.
Did you try reading the directions that came with it? I can tell you that the black wire with white stripe coming from fan is the light wire.
Apr 01, 2016 | Hunter 52" Ceiling Fan With Light And...
Wiring diagram for hunter remote part 98480-02
I don't know what remote you have but try this;
Bk to Bk
Wh to Wh
Black w/wh stripe to red
Black to house black
White to house white.
fanman9952@aol.com
Sep 08, 2014 | Hunter Dryers
How to attach and wire my controller for my remote control
What model do you have? If it is an add-on remote, then follow instructions here:
1) Black on end of receiver to black in ceiling.
2) white ( next to black ) to white in ceiling.
3)Other White to white in fan.
4) Black to black in fan.
5)Red or black w/ white stripe to blue or black w/ white stripe.
Oct 16, 2013 | Hunter 52" Ceiling Fan With Light And...
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
Jan 28, 2012 | Hunter Ceiling Fans Individual...
I purchased a hunter universal remote and have a hunter fan with canopy I am trying to get it hooked up to. I have all wiring configured the way it shows on diagram and still nothing. From the box in...
If everything is wired correctly, disconnect power at the source, then reconnect power and experiment with every possible combination of wall switches and the remote until the fan works correctly. At that point, do not use the wall switches again, ever.
Apr 17, 2017 | Hunter 27187 Remote Control
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
Wiring a ceiling fan with light fixture. there is a black and white stripe wire, one black wire, one white wire and ground wire. Coming out of the ceiling is two black and one white. one copper. please...
The black and black with white stripe are for the light and fan respectfully. The white wire is your neutral. That leaves the ground to your copper ground wire. If you have two seperate switches to operate the fan and light then the two black and black with white will tie in to seperate black supply wires. If only one switch then they will tie in together to the black supply wire.
Sep 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
132 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
