Question about Coffee Makers & Espresso Machines
Will blower motor resistor stop blower motor from running
  • 2,509 Answers
It depends which resistor, it could stop all speeds working or only one speed. The basic answer is yes it could, but you need to measure the voltage to see if that's the problem. Why did you post this under coffee, is it a blower in a coffee machine?
Posted on May 14, 2014
Blower for heater stopped running
There is a blower motor resistor in the system, and they do wear out. However if you heard the motor was having issues, I would check that out as well. Here is a video on changing the blower motor resistor:
Feb 10, 2017 | Chrysler Cars & Trucks
Tip
No heat blowing
on most vehicles when the heat stops blowing it's usualy not a fuse or a relay but the blower motor or the blower motor resistor.
Here is a good way to check if it's the blower motor. Disconect the plug going in to the blower motor, Now run two long wires from the battery one on the negitive and one to the possitive. put power to the blower motor with theese wires, negitive to one post and possitive to the other .Does'nt matter what post you hook to the blower motor will just spin the opisite way. if the blower motor spins then you can rule out the blower motor and suspect the blower motor resistor is bad. to find the blower motor resistor all you have to do is follow the wirring from the blower motor. The resistor will be at the end of the wirring for the blower. The resistor will be mounted on the heater box near the blower motor and is usually held in by two screws.
on Feb 11, 2010 | Chevrolet Cavalier Cars & Trucks
05 tahoe blower motor do not stop
check blower motor resistor connector could be burnt or resistor it self
Jan 30, 2015 | 2005 Chevrolet Tahoe
Will bad blower resistor cause blower to stop working at all?
yes a bad resistor will. but also check the blower motor
Sep 14, 2012 | 1999 Buick LeSabre
Air conditioning and blower stopped working, all fuses checked good.Is there a common feed to these two circuits?
The answer is that there is dirt dust and fuzz built up in the brushes of the blower motor. Had to figure this one out myself. Remove glove box, carefully disassemble bottom of blower motor, remove brush cap and brushes clean up mess and reassemble. Not for a novice but if you're a thinker you can figure it out. Mine has worked every time since. The Pontiac guys had no clue wanted to replace motor.
May 21, 2010 | 2004 Pontiac Vibe
The HVAC blower fan on my 2001 Pontiac Aztec stopped working on settings 1-3 several weeks ago. Last week it stopped working at setting 4 and today it stopped working all together. What is the most likely...
the blower not working on settings 1-3 is the blower motor resistor. this limits the power provided to the blower motor itself to change the speed. at setting 4 it is getting full power. since it quit on 4 also, i would still say the resistor needs to be replaced first, then see if the blower comes back. you may also need a blower motor. if you have a voltmeter you can just turn the switch to 4 and see if the motor is still getting 12 volts. if it is and doesn't run, it needs a blower motor too. if it's not, then its just the resistor
Feb 24, 2010 | 2001 Pontiac Aztek
MY HVAC fan stopped blowing. Checked all the
Check the blower motor speed control resistor pack is ok.
(The resistor pack is usually located in the blower fan ducting in the air flow).
Check condition of electrical connection terminals on the blower motor circuit - these terminals pass considerable current and over time may fatigue overheat and loosen.
Check operation/replace any blower motor control relay,
Check the blower motor will run if +12v directly applied to the blower motor.
Check operation of the blower motor speed control switch is ok.
Oct 08, 2009 | 2003 GMC Sierra
Replacing Blower Motor Resistor
  1. Disconnect and isolate the battery negative cable.
  2. Open the glove box.
  3. Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening, then roll the glove box downward.
  4. Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the blower motor resistor from the resistor connector receptacle (Blower Motor Resistor).
  5. Reach through the glove box opening to access and disconnect the blower motor pigtail wire connector from the resistor connector receptacle.
  6. Remove the two screws that secure the blower motor resistor to the evaporator housing.
  7. Remove the blower motor resistor from the evaporator housing.80ac4e54.gif
Feb 04, 2009 | 2003 Chrysler Town & Country
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
