Question about Symphonic WF-719 19 in. TV/VCR/DVD Combo
TV won't release my DVD when I press open/close
    Problem Solver:
  • 6 Answers
Make sure the TV is in dvd mode ( if it is in any other mode it wont work)and press the eject button on the remote first, if that does'nt work try the manual eject button on the front of the TV (hold it for a few seconds)if neither of these work you will need to have someone open up the back of the TV and check the tray and motor. Some combos have a release like a PC DVD ( a tiny hole on the front of the dvd tray) and a paper clip can be used to release it as far as I can remember the old WF-719 combo does'nt.
Posted on May 27, 2014
    New Friend:
  • 141 Answers
You need to reset your tv and this shoud solve the problem if not let me no
Posted on May 22, 2014
My Panasonic DMR E S45V just stopped working. The Error message is F04. The DVD door won;t open, the VHS door won;t close.
Check the servo unit to see if the actuator is changing modes when press the buttons. If one door is open the other will not function either.
Feb 02, 2015 | Televison & Video
Dvd player won't play
It sounds that the laser pickup unit of the DVD player have damaged. Check and replace it.
Jan 09, 2013 | RCA TruFlat 27F520T 27" TV
The DVD player keeps opening and closing and won't play/load DVD's. What could be the problem?
There are sensors which tell the DVD drive that the drawer is closed and that there is a DVD inserted, if these fail there is usually no simple fix, the parts need to be replaced which requires complete dis-assesembly of the TV/DVD, Most people just choose to connect an external DVD as it is cheaper.
Mar 07, 2012 | V7 VC2607 26 in. LCD TV/DVD Combo
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
DVD player doesn't work.
Problem fixed
Thanks Anyways
Feb 04, 2009 | Samsung TXM3298HF 32" TV
I need the universal code for my bush dvd player?
TRY THIS. It works on my Philips DVD player: To make some DVD players play disks from different regions. 1. Connect DVD to TV ensuring both are then switched on. 2. Press "OPEN/CLOSE" button on DVD player. 3. Enter "8421" using remote control. 4. While watching TV screen repeatedly press "Select" on remote control until region 9 is reached.  5. Press "OPEN/CLOSE".
Dec 18, 2008 | Televison & Video
The dvd draw will not open when I press the open/close button.
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Apr 08, 2008 | Philips LX9000R System
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
Symphonic WF-719 19 in. TV/VCR/DVD Combo Logo
187 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
