Question about Ambico Photography
Need to purchase a head plate for VCT-PG11RMB
  • 685 Answers
Http://www.tripodquickrelease.com/Ambico_Quick_Releases.htm This site may have something
Posted on Nov 08, 2014
4 Suggested Answers
SOURCE: looking for quick release plate for vct-1170rm tripod
try contacting email@spartanphotocenter.com
They specialize in quick release plates, and I just ordered one for my Sony tripod.
Posted on Apr 16, 2008
  • 685 Answers
SOURCE: Need quick release plate for Sony VCT-D480RM
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Posted on Jun 22, 2010
sgavhane
  • 101 Answers
SOURCE: I lost my VCT-R640 tripod
P/L GO YOUR NEAREST SONY SERVICE CENTER WITH YOUR TRIPOD BILL AND CHANGE YOUR TRIPOD PALTE
Posted on Oct 08, 2010
I need a qr plate for a sony VCT-1500L tripod
That model is not listed here: http://www.tripodquickrelease.com/Sony_Quick_Releases.htm
but check the sizes to see if it might fit.
May 14, 2014 | Sony VCT-1500L Tripod
Sony VCT-1170RM Tripod quick release plate
May 10, 2014 | Sony VCT-1170RM Tripod
Need Quick Release Plate for Sony VCT-1500L Tripod
Go to this page: http://www.tripodquickrelease.com/Generic_Tripods.htm
they have descriptions on how to measure your tripod and a list of popular quick releases.
Feb 06, 2014 | Sony VCT-1500L Tripod
Adapter connect sony vat-60av to canon vixia
You need a quick release plate that will attach to you camera and then your camera will snap into place on your tripod. Take a look at www.TripodQuickRelease.com
Jan 27, 2013 | Sony VCT-60AV Remote Control Tripod,...
Where is vct solenoid
Hi there:A code P0012 refers to the VVT (Variable Valve Timing) or VCT (Variable Camshaft Timing) components and the car's PCM (Powertrain Control Module, also called an ECM).
That consists of a few different components but the P0012 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is over-********, the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
A P0012 DTC trouble code may be caused by one or more of the following:
- Incorrect camshaft timing
- Wiring problems (harness/wiring) in intake timing control valve control solenoid system
- Continuous oil flow to VCT piston chamber
- Failed timing valve control solenoid (stuck open)
On Ford, the VCT solenoid is located at top of cylinder head underneath the valve cover and goes around one camshaft. You will need to remove the valve cover, the timing cover, then remove the timing belt, the camshaft sprockets, and finally the camshafts to remove the vct solenoid as it goes around the camshaft. You can use 2001-2003 models with same engine.
VCT or Variable Cam Timing solenoid is a device used in modern engines to change camshaft position timing in relevance to engine speed and engine timing allowing the engine to produce more horsepower without adding excessive overlap to the camshaft design.
The way the VCT Solenoid works is as follows:
The VCT solenoid works with oil pressure, it receives a signal from the ECM when the camshaft needs to be rotated either in the advanced mode or ******** mode depending on engine load and speed.The VCT solenoid is able to accomplish that by altering the oil flow in the passages that lead to the cam phaser(s), there are passages to advance the valve timing ( open the valves earlier), and passages that direct the oil to ****** the valve timing ( open them later)
The purpose of the VCT or Variable Cam Timing system is to allow the engine to move larger volumes of air in and out of the cylinders to generate maximum horsepower.
Vehicles with DOHC ( Dual Overhead Cam ) engines usually have two VCT solenoids mounted in each cylinder head, one for each camshaft, allowing the Engine Control Computer to activate each VCT timing mechanism in each Camshaft separately.
NOTE: The Cam phaser is mounted on the front of the camshaft(s) it is driven by the engine's timing chain or timing belt depending on the engine's design.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 20, 2012 | Cars & Trucks
I lost my VCT-R640 tripod quick release plate. I need a replacement soon. Please help
Oct 08, 2010 | Sony VCT-R640 Tripod
Need quick release plate for Sony VCT-D480RM tripod.
Jan 13, 2010 | Sony VCT-D480RM Tripod
Need a mounting plate for Sony vct870 tripod
The Quick Shoe that came with my VCT-870RM has a part number of QB-6RL. I was successful at finding this part when I could not find the Sony part 397200301.
Jun 12, 2009 | Sony VCT-870RM Tripod
What type of quick release is in VCT-r640 SONY TRIPOD
they don't have that model listed, but they seem willing to try. Several people are thanked for finding out which plate fit which tripod.
Dec 15, 2008 | Sony VCT-R640 Tripod
Looking for quick release plate for vct-1170rm tripod
Mar 10, 2008 | Sony VCT-1170RM Tripod
Photography Logo
66 people viewed this question
Top Ambico Photography Experts
Tony
Are you an Ambico Photography Expert? Answer questions, earn points and help others
