Question about LG Televison & Video
Do i need a usb cable to connect my digital tv recorder to my lg 578 tv.
    Top Expert:
  • LG Master
  • 75,591 Answers
No need for it. You should have a digital interface cable. Gopakumar Gopalan Google
Posted on May 14, 2014
Can you record from a smart tv with arecording box
First of all you need to check if your TV supports recording. Some 2010 models do and most 2011 have it implemented. Look for stickers or logos such as:
  • USB Recording
  • PVR (Personal Video Recorder)
  • DVR (Digital Video Recorder
  • The following manufacturers support it in some of their models. Typically mid-end to high-end models. Check the manufacturer web site if you are unsure.
  • Samsung
  • Sony
  • LG
  • Philips
  • Panasonic
  • Toshiba
  • Sharp (only Time Shift pausing)
  • Grundig
    What you need
    Many consumers have USB recording enabled TVs without actually using the function - simply because it requires an extra USB hard drive ou need the following:
    1. USB Recording: A HDTV that supports recording.
    2. A USB HDD: FlatpanelsHD uses a USB HDD from Transcend.
    3. Digital channels: Recording is only enabled on digital channels - not analog. You can record SD, HD and 3D.
    Some manufacturers recommend USB hard drives with external power supplies but we have used a Trandscend USB HDD that takes power from the USB plug on all manufacturers' TVs without any problems. Manufacturers typically allow 1:1 recording, meaning that you will see no loss in picture quality.
    How to set up USB Recording
    Once you have purchased a USB hard drive and connected it on the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  • Connect the USB HDD to a free USB port on the back of the TV.
  • The USB hard drive now needs to be formatted (all data will be deleted).
  • Most TVs help you to format the USB HDD automatically but on some models you need to enter the menu and select format HDD (or something similar)
  • Sep 29, 2016 | Televison & Video
    Lg flatron m198wdp digital tv monitor
    Hi, I am guessing the only way is to buy the needed cable and a Digital Tv Receiver like this on ebay, they are really handy and you can also record it to a external device such as USB Drive or Memory Card, just see the details of each one and choose the best for your needes.
    Oct 16, 2013 | Televison & Video
    No audio after recording from sat. Reciever
    Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
    If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
    Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
    The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
    I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
    Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
    G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
    You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
    Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
    I HAVE A LG 32LD 490,CAN YOU TELL ME HOW I WATCH WHAT I HAVE RECORDED ON THIS SET,MANY THANKS.
    There is no Digital video recorder built into the TV, so how can you record something unless you have an external DVDR connected?? This TV only had a Digital Tuner built-in.I am sure you are aware the USB is only for playback.
    Mar 10, 2011 | LG Televison & Video
    How to record digital tv thru reocrder
    You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
    May 29, 2009 | LG RH177 DVD Recorder/HDD Recorder
    Connecting LG DVD recorder to cable box and HGTV digitally
    Two things come to mind: copy protection and resolution settings.
    The TV may not allow copy protected material to come from your LG, or the sampling frequency may be unacceptable. On page 15 of the manual it talks about 96kHz and 48kHz frequency settings. The third thing to check is the vertical resolution using the RES button on the front panel. SDTV is 480, and HDTV is anything above that. Using the HDMI is supposed to allow upconvert to 1080i max if your set can use that resolution.
    tom
    Jan 02, 2009 | LG DR787T DVD Recorder
    User Manual
    Why did you disconnect the chat session?
    Anyways here are the detailed instructions for connecting a DVD recorder to a TV
    1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
    2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
    3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
    4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
    5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
    6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
    7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
    8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
    9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
    10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
    11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
    Sep 27, 2008 | Televison & Video
    Hooking up a DVD player to a LCD TV
    Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
    Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
    Televison & Video Logo
    46 people viewed this question
