Question about Jandy Aqualink Rs4 One Touch Control System Control System
I would like to know how I can change the pump mode to work automatically for 8 hrs at night
  • 3 Answers
Just delete your current program and "add" a need one. In this field, it allows you to set the hours of operation you wish.
Posted on Jul 07, 2009
Sidebyside kenmore works great for 12 hr. then seems to go into defrost mode and won't cool unless i unplug for 6 to 8 hrs plug it back in and it works fine for 24 hrs then repeats
Larry I tried to write the solution here but it would not send. Click Here=> Kenmore Appliance Model Number Locator and examples Your solution is at top and center of that web page. Let me know if helpful or if you have more questions, Thank You, Sea Breeze
Nov 16, 2011 | Refrigerators
The intex system light is green ,but when i test water no free chlorine is registered
I have an 18 X 33 X 48" oval pool (14000) gallons and I run my pump in the summer months at 10 to 12 hrs and chlorinator at 8 to 10 hrs of those pump hrs and hit a chlorine level at 2.0 to 2.5 ppm.. Green chlorine light means you are generating, it does not mean you have the correct level.. Increase your cycle time and check after 3 days... Please post a comment if this helps! Good luck,,
Aug 08, 2011 | Intex Automatic Salt Water System for ...
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
The night time video doesnt work and the screen is black. It works fine during the day. Not sure what has happened to the night time mode. Even when plugged into the ac adapter the screen is still black...
It sounds like the Infrared LED are not on (there are 8 of them on the fornt of the unit), it should automatically turns on when it senses dark scene. You can find out at night using the digital camera pointing at the LEDs, you should see white glow on your digital camera.
The problem can be caused by the power supply that supplies the power the LED assemblies or the detector circuits that suppose to turn on the LED when the surrounding area is dark has failed.
Jun 24, 2011 | Summer Infant Additonal Camera for Video...
Heat pump is in heat mode 4 hrs. in to the
Hi, this is your programmable thermostat not being programmed right. If you have the manual, set your times and temperatures for both heating and cooling to cool or heat at the times you want it to. I am not sure where you are, and if you want to use just heat or cool, but you can set it to run on just one or the other, or to auto change over. Just be sure to run it in the auto mode. I can't tell you how to over the net as there are so many models of thermostats, but if no manual, you may be able to get one by getting the model number off your stat and name, go to a place that sells that stat and they can tell or show you how to set it up. I hope this has been of help to you. Let me know please.
Shastalaker7
Dec 23, 2009 | Ruud Handle Air Conditioner
Phone in night mode
go to EXT 100 and program a key with a code 560.
you will do that by pressing the menu or F1 key and then fallow the steps for programming a key.
once you have programmed the key press it once and the display will start changing from night to day to holiday, pick the day and you are done.
Better yet, go to the phone that has on the display word NGT/night, or DAY, HLDAY and press the each key until the display changes that word on the display. one of the keys is programmed with key code 560. the phones that do not show Day, Night and Holiday will not have the key.
let me know if this does not work for you, or you need other help
Oct 07, 2008 | Executone 64 Corded Phone
Defrost timer
The timer has a rotation 24/7 every 6 to 8 hrs. depending on timmer set up it goes into defrost... there is No way to adjust when it will defrost.
Sep 19, 2007 | GE (GTS16BCS) Top Freezer Refrigerator
Jandy Aqualink Rs4 One Touch Control System Control System Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
