Question about Canon PIXMA iP90v Printer
Canon ip90 has a new print head and ink cartridges but does not print, only goes through the motions. What is the problem?
Cleaning multiple times does nothing, nor adding a different cartridge.
    Problem Solver:
  • 11 Answers
Remove the cartridges and press the end with the ink sponges onto a paper towel. If you see ink on the towel, insert the cartridges and run the cleaning 3-7 times. This will use up some ink, but is the only way to resolve this issue. If you continue to see improvement in the prints, continue to clean until quality is acceptable.
Great Tech Support by TechbuddiesOnline Call 1 855 517 2433
Posted on May 14, 2014
  • 105 Answers
SOURCE: Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
Posted on May 12, 2008
  • 68 Answers
SOURCE: Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
Posted on May 28, 2009
SOURCE: IP90 stopped printing black
I switched to composite black, then back to all black. After composite black printed out, then all black was ok. It was a software problem, not a hardware problem. Try this first! Mike from Burlingame
Posted on Feb 15, 2009
komguy
  • 2306 Answers
SOURCE: Canon PIXMA MP500 New Black ink cartridge produces no ink
If you don't use it very often the black could have dried in the printhead, and you will need a new one. Another possibility is that the purge unit is not cleaning and priming the printhead properly. I have seen several defective purge units. For 1 year it can be replaced under warranty, after that it is a $90.00 repair job in the shop.
Posted on Jun 25, 2009
SOURCE: New ink cartridge. Canon ip1800 series print is pale
printer ip 1880 lampu kuning n hijau kedip...kenapa...pertanyaannya pasti cartridge tdk terpasang dg baik...pdhl ush terpasang..???
Posted on Dec 24, 2009
My Canon IP90 printer in printing blank paper
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaces.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new injet printer.
Jan 16, 2011 | Canon PIXMA iP90 InkJet Printer
Canon pixma ip90 printer is not printing blue colours. i've tried cleaning but it doesn't work.
If the blue ink cartridge is not empty, then it means that either the pront head or the ink cartridge is clogged. Here are some information about ink cartridge cleaning, and here you can find some information about print head cleaning.
Nov 24, 2010 | Canon PIXMA iP90 Mobile Printer
Printer goes through the motions like it's printing, I don't get any error messages, you can see the ink cartridges moving back and forth, it pulls paper in and acts like it's printing, but the page comes...
Sep 30, 2010 | Canon PIXMA iP90 Mobile Printer
My new canon ip90 printer won't print anything goes through all the motions but no ink comes out. brand new cartridges in it?
Is the shipping cover still on the printhead? If it has been removed, wipe the printhead with a damp paper towel to see if the head is plugged. If ink is present on the towel, do a print head clean from the maintenance menu.
Oct 11, 2009 | Canon PIXMA iP90 Mobile Printer
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
Canon iP90 will not print black text - it will print any other color text. When I print a test page - it only prints the small flag top left page. I have done a deep cleaning - three times. I have replaced...
hi karen,
If you are sure that the ink is present, there two other possibilities: Purge unit work properly so the ink cannot flow down from ink tank or Logic board of you printer is faulty.
Dec 13, 2008 | Canon PIXMA iP90 InkJet Printer
Canon I470D not printing
may be your cartridge is empty or try out head cleaning to run the flow of ink into the new head.wish u success!
Jun 04, 2008 | Office Equipment & Supplies
Black has stopped altogether
He says he replaced the cartridge twice. Possibly (most likely if it is an iP90 since after-market versions are rare) these WERE the OEM Canon cartridges! Therefore, the head assembly (a separate component, that holds the iP90 cartridges) is obviously the problem. Do this: I have written this for the Canon iP90. Generally, this will work for any printer that has print heads that are SEPARATE from ink cartridges. For example, older B/W BJ2 family Canon/Apple StyleWriter printers have ink cartridges that INCORPORATE the print head into the cartridge -so this will NOT work on them! (although I once succeeded in cleaning the heads, it was VERY messy and took several days, then required another trick thereafter). Also be aware that this is for B/W or Color printers that use water vehicle (water based) inks only (most are water-based, but some printer inks are alcohol, oil or acetone based). The appropriate vehicle/solvent must be used, and the WRONG solvent can damage heads! (for example, using water, alcohol or acetone for cleaning oil based ink cartridges can be disastrous). RESEARCH your ink "base" first, if you do not know what it is! iP90 Head Cleaning by DanaSaur: 1 These ink cartridges are grey. Remove both cartridges. 2 Now remove the head assembly that held the cartridges (black, with 3 small round seals and one large seal) (consult manual, in NEW setup sections, if still uncertain how). DO NOT TOUCH ANY PART OF THE SMALL WHITE PAD BENEATH THE ASSEMBLY. 3 Now take this whole assembly ONLY, (it is 4.5cmx5cm, 1.5inx2.0in) and drop it into a small container of warm water. DEFINE WARM: Think of a range between a "baby bottle" (slightly above body temp) up to any temp that does NOT cause pain/discomfort to the underside of your wrist!) Let it soak 30 minutes. 4 Take a NEW, CLEAN, SOFT toothbrush, dip it in warm water, and GENTLY clean the small components on the white pad below, AND the 4 seals inside the head assembly. 5 Rinse everything (even toothbrush) in warm water, under a faucet, until all items are clean (no color appears in water). 6 Repeat steps 3, 4 and 5 above (but can use the same toothbrush) This time though, leave assembly in water 2-3 hours, keeping it warm (replace water every 20 minutes or so). 7 Rinse everything again, as in 5 above, gently tap off excess water (DO NOT TAP WHITE PAD FLAT AGAINST ANYTHING -ONLY CORNERS) 8 Set assembly white side down, yet tilted on a corner with a pen or clean 0.5-1cm object, on a smooth, clean surface in a closet (or other isolated environment, to avoid dust/lint etc). 9 Set a small piece of tissue wadded up and soaked with water, in the same closet (but not too close to head assembly). This will be your "advanced, high-tech, moisture level gauge" :) 9. Allow the tissue to COMPLETELY DRY... even to its core! When this has happened (may take several hours -or day in colder weather) the head assembly is dry enough to re-install in the printer. 10 Install cartridges (may be best for you to buy new ones, sorry). Let them gravity flow with natural capillary attraction for a few hours (or allow a day if room is cool/cold). Always keep printer lid CLOSED to avoid drying out ink/clogging heads or capturing dust/lint from atmosphere. 11 run head cleaning process as many times as it takes to re-saturate heads with ink. 12. Now, after doing all these steps faithfully, if printer has not started working, you let the heads dry out way too long, or contaminated them with touch (skin oil) or the wrong solvents. You will need to BUY a new head assembly. Bend over bud, this is what gets Canon accountants ****! This is why they offer cheap printers -to extort obscene amounts of money when you need parts :)
May 14, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA  iP90v Printer Logo
116 people viewed this question
old marine
old marine
