On a 2008 sportage a red symbol appeared that looks like a person sitting with a seat belt on and around red circle in front of the person what dies that mean
SOURCE: 2000 Kia Sportage just "died"
check your fuel pump should be able to hear it when you turn key on you can pull your backseat up and there is a small plate under it have someone turn key on and you listen should make some kind of noise if it working
SOURCE: 2005 Kia Sportage serpentine belt
YOU NEED THE BELT TENSIONER TOOL ITS FITS IN THE SQUARE SLOTS IN THE TENSIONER.YOU ROTATE TENSIONER CLOCKWISE TO REMOVE BELT.
SOURCE: warning light with a tire and an explanation mark
you have sensors in each tire that warns you of lower tire pressure just put some air in your tires to specs and the light should go out.
SOURCE: 2001 Kia Sportage runs rough
Yes my frend open the bonnet and stand infront of the car, on the left hand side between the engine and the boddy there is a black round container with pipes going into it. next to the container there is a vacume switch, 99% of the time this pipes going into the switch is brohen or the pipe is leaking. Enjoy Willem SA
