Question about Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows
Where are my storage device policies
I need to change the read/write policies on a 64g pen drive and cannot find Storage Device Policies in regedit thanks
  • 115 Answers
Open up 'This Computer'
Right click on the device and select 'Properties'
Click the 'Security' Tab
Change Permissions
Posted on May 20, 2014
I can't remove write protection from ur suggestion....in registry editor i hv no storage device policy
You can remove write protection from your drive using the below method:
Open start menu, in the search bar type regedit and press enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key Storage Device Policies does not exist, you will need to create it manually.
Double click the key Write Protect in the right window and set the value to 0 in the Value
Data Box and press OK button
Restart your computer and try copying files into your USB drives.
or you might
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
Apr 12, 2012 | Computers & Internet
How do I remove the 'write-protection' on my DANE-ELEC 4GB flash drive?
if you are using windows as your operating system then follow these steps below
1.click on start 2.click on run and then write regedit or regedit32 in run window 3.next it will open a new window's which is Registry editor locate HkEY_LOCAL_MACHINE\SYSTEM\CURRENT CONTROL SET\CONTROL 4. Locate sub key storage device policies and then locate Dword value Write protect for disabling write protection you have to set value to 0 if it's 1 there !!!!
Sep 21, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Anytime a flash drive, mouse, keyboard, or any USB device it wants administrator rights. Very annoying in a lab situation where everyone has a different flash drive.
A user with an administrator account will probably have to edit the policies of the machine by in the run box entering gpedit.msc, you will be looking for usb device policies or device installation policies. I am not sure of the exact policy that you will have to change, since windows by default doesn't ask for administrator rights to use flash drives.
May 12, 2011 | HP Compaq dx2450
Cannot act because it isays procted against writing does not have storage protection policies
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
May 10, 2011 | Computers & Internet
How to remove the write protection om my usb. I tried to open HKEY_ Local_ Machine and i cant see the storage device policies. Can u just tell me how to solve this problem
also
- Click permissions
hope this helps
Apr 20, 2011 | Computers & Internet
Sir good after. I have 4GB transcend 2.0 pendrive while copy some thing to penrive this drive a message is comming like " this disk can not be written to bacause it is trite protected please remove...
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
Mar 20, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i plug my pen drive in it shows up as 2 locks , click on 1 UNLOCK comes up , click on tht as normal it just disapears , so i cant unlock ? plz advise , it as been working fine till today?
also
- Click permissions
also you might
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Mar 17, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
Storage device policies is missing in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
Oct 10, 2010 | iLO (2 GB) MP3 Player
My Kingston 4 GB Pen Drive became Write Protected.
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type reg edit and press Enter, this will open the registry editor.
2. Navigate to the following path:
Note: If the registry key Storage Device Policies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key Write Protect in the right pane and set the value to 0 in the Value Data Box and press OK button
Please rate me if this solution works for you
Thanks......Have a great time
Jul 02, 2010 | Electronics - Others
Removal of write protection
try to scan the drive and then safely remove
May 24, 2009 | Kingston Technologies 512MB DataTraveler I...
Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
