Question about Kitchen Ranges
I have a whirlpool rf368lxpb 1 range. When I turned on yesterday there was a pop sound. The light saying the burner comes on but the burners don't heat also I checked the oven same thing the heating element does not come on Is there a fuse or breaker within the range I already checked the breaker in the fuse panel and it is fine
    New Friend:
  • 102 Answers
Try shutting off the main breaker then turn it back on. This works then ok you would know that there could be a loose connection or bad breaker. Hope this helped
Posted on May 14, 2014
  • Wayne May 14, 2014
    Already tried that had no effect
2 Suggested Answers
SOURCE: heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Posted on Jan 17, 2011
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
I have model SF114PXSB2 and want to know can I turn the lowest heat setting to a lower setting on the range top. Right now the lowest setting is still too high.
This should be a gas range according to #. Sounds like burner valve worn out.
You should replace your burner valve for that burner. I don' t believe they are adjustable.
$50 part at Sears.
Feedback appreciated
Aug 03, 2011 | Whirlpool Kitchen Ranges
I have a Whirlpool Super Capacity 465 Gas Range. However all the burners on top will not click to ignite. I turned the breaker off and that back on again and it worked for a day or two. Now nothing will...
Power for the ignitors goes straight from the input power to the burner switches then on to the ignition module. The burner switches are in series parallel. Any one of them actuated will provide power to the ignition module.
See the schematic in this pdf file page 22 but page labeled pg 20: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ca8e028c60d9804f85256a8c00621f04/$FILE/4322089.pdf
When the ANY burner control is turned on all 4 ignitors do cycle.
Does the oven burner light? If not you most likely have a bad ignition control unit. Item 35 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=242126&diagram_id=32025#d32025
If the oven burner lights then you most likely have a wiring problem to the burner controls. There is ONE power lead that if it comes loose will cause all of the ignitors not to work.
You can use the https:// manual link above to gain access to the top of your oven. See page 15 of the .pdf file.
The igniton system is explained starting on page 19 of the pdf file.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Whirlpool Kitchen Ranges
My whirlpool range ss630per-1 burners will ignite except of front right which give no ignitor sound at all, but the Rear Right works fine. any solutions?
Each burner control knob has a built-in switch that controls the igniter. It appears the front right burner switch in the knob is possibly defective. They are replaceable but it requires dis-assembly of the range front. Are all the igniters in a sequence? Have you tried turning the front right burner on while another burner has the igniter on. This may let you ignite the burner automatically. When you have another burner igniter clicking try turning on that burner. If the range has rectification igniters that will not work.
Sep 26, 2009 | Kitchen Ranges
My Whirlpool electric range made a loud electrical popping/cracking noise followed by smoke. Now the indicator light for the left front element is always on. Also when we try to turn on any burner the eft...
Sounds like you have a short in one of your burner switches that may have also taken out your main control. Does your oven work normally? Those error codes are related to 1] control board and 2] oven over temp, so the burner issue is unrelated except in that it may have surged the control.
you can view the switches by removing the rear panel(if this is a freestanding range) and from the description you will likely see the shorted component with some black marks around it. Please unplug the range first,as these wires are live even when all burners are off
Sep 02, 2009 | Kitchen Ranges
Heating elements
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Range burners don't stay on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545111
Generic problem for all Kitchen Ranges
Posted by swetepi on Apr 25, 2008
I have a freestanding electric range that I purchased 1.5 years ago from Best Buy and rarely used. This is a sudden problem that began yesterday. All the burners come on , but stay on only 1 second, then go off for a minute then come on again for a second. Whirlpool will not give any technical support at all.
I can' afford to have a repair man out. I do not know how to get at the control panel. Can you help? I will never recommend Whirlpool.
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
You may check your factory owner’s manual under the trouble shooting guide to see what is happening. Do you have a glass top or the top with metal burners?
If you have the kind with the metal burners the top in most cases are on a hinge and will lift up for service, you definitely have a short somewhere or a loose connection, check with Whirlpool’s customer service to see if they can send out a owner’s manual from the factory or check to see if it is still under a factory warranty and if it is there would be no charge. Or check with your local Whirlpool appliance dealer – sometimes they can be of some help. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://whirlpool.com/home.jsp
Contact Us
Hours: M-F 8am–8pm Local Market Time
S 8:30am–5pm Local Market Time
- Get shopping help
- Order parts and accessories
Call 1-866-698-2538
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Apr 25, 2008 | Kitchen Ranges
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
