Can the digital audio port on my BDV-E679W be repaired easily
The digital audio port has stopped working, is it an expensive fix?
    Sergeant:
  • 376 Answers
Yes.... with the right tools and proper parts.
Posted on Jun 25, 2014
My Sony str-k6800p is in protect mode how to fix
Something is drawing too much current inside. Chances are it has a bad output device. Repair is more expensive than replacement. Look for one on eBay that works, but has missing knobs or something that you can easily swap. Should be under $50.00.
Apr 17, 2015 | Sony Audio Players & Recorders
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
"RM OFF"
I am having the same problem - did you find a way to fix this???
May 11, 2014 | Sony BDV-N790W 3D Blu-ray Home Theater...
Sony 5.1 home theater in protector mode help me to fix this problem
You unit is most likely has DC Offset(a damaged amplifier). Unless you are an audio specific technician, this repair is not a DIY. If you'd like more information, or would like to inquire about having your Sony repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Apr 15, 2014 | Sony Bdv-E780w - Home Theater System - 5.1...
Onkyo tx-nr808 sound stopped working
These units have a common problem with the firmware not being able to load correctly. Only way to really fix it is to replace the digital board - really expensive repair. Can sometimes be fixed by reheating Q3001, but this doesn't always work.
Nov 27, 2013 | Onkyo Audio Players & Recorders
Denon AVR and PS3 issues
Sounds like a problem with the digital board. Expensive fix - hope it's still under warranty.
Jul 02, 2013 | Audio Players & Recorders
Stuck in demo mode / demo lock
Put the unit in dvd mode. then press and hold the stop and eject buttons. The display should read "demo off". Then the tray should operate normally.
May 28, 2013 | Sony BDV-E280 Home Theater System - 3.1 3D...
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
My marshall mg100hdfx digital fx rack wont work
sounds like the effects module has stopped working . you could try re-working the joints around the i.cs on that board if you have a rework station. i have only managed to repair one baord this way suggest replacement is the best course of action. uk cost of panel approx £50.00 + fitting
Jan 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Onkyo TX-SR701 Digital audio port stopped working
you may want to try a factory reset by pressing and holding vcr1 button while pressing the power button. do this with the unit on. It will reset back to factory default. so any saved setting will be lost and you will have to set again to your settings.
Jan 03, 2010 | Onkyo TX-SR701 Receiver
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
