Question about Dell Office Equipment & Supplies
How do I fix my Dell 1230c it smears down the middle of the page
When I print the ink/toner smears down the middle of the page.
maverick24
  • 56 Answers
SOURCE: print jobs smeared
Hi Are you using OEM or rebuilt toners? If your using OEM and your able to smear the ink with your finger more than likely you have a fuser problem?. If your using rebuilt cartridges it could be the cartridge. Good Luck!!
Posted on Dec 03, 2007
Tirzo
  • 94 Answers
SOURCE: black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
Posted on Jun 10, 2008
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Posted on Jul 17, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
CompuGuy44
  • 432 Answers
SOURCE: Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
Posted on Aug 08, 2009
I have a black line printing down the middle of the page that smears when touched
U didnt write what model of machine you hawe,but probably,I thinh the fixing roller or film on your's machine heater is damaged
Oct 10, 2014 | Canon Office Equipment & Supplies
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
Magenta toner smearing and there is also a line down the middle of the page
This is most likely due to a problem - like a crack - with the scraper on the drum cartridge that keeps the photoconducter clean. You should probably have that replaced, and replace the drum as well. FWIT, you should never touch the photoconductive surface of the drum - you can damage it, or leave fingerprints on it that will affect the print quality.
Oct 06, 2010 | Dell 5100cn Laser Printer
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
Colored ink is smearing on the page when I print
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
May 07, 2010 | Canon imageRUNNER iR C4080 Color Copier
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
I bought a refurbished toner cartridge for my printer a few weeks ago. Now it smears the ink! How can I fix this?
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Jan 29, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Print jobs smeared
Nov 28, 2007 | HP LaserJet 2550L Printer
HP Laserjet 1022
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Nov 15, 2007 | HP LaserJet 1022n Printer
115 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
