When i power on the machine, it can't accept any instructions. and it displays PE blinking. how can
How can i fix it? the machine is trubodrum.
  • 2,013 Answers
Could be water pressure sensor. Read this.
http://appliancejunk.com/forums/index.php?topic=11491.0
Posted on May 14, 2014
My washing machine LG - model # T7517TEPT0 is displaying PE error - please advice to enable to fix the repair
PE stands for locked rotor meaning the motor is not able to turn either electrically or physically
May 01, 2017 | LG Washing Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
How can I fix my washer
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE.
Mar 08, 2018 | LG Washing Machines
Getting pe error
Whirlpool Washing Machine Displaying Fault Code PE The part(s) or condition(s) listed below for the symptom PE - PRESSURE SENSOR ERROR // Water level pressure switch error are ordered from most likely to least likely to occur. Check or test each item, starting with the items at the top of the page.
per https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/408-5--/Whirlpool-PE-PRESSURE-SENSOR-ERROR-Water-level-pressure-switch-error
b2kjqj
Dec 09, 2017 | Whirlpool Washing Machines
White Magic 650H. Why is error code PE displayed and water reuse LED blinking?
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Sep 29, 2013 | Whirlpool Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
Free instruction manual for brother embroidery machine pe-180d
You can download and print the instruction manual in PDF format from Brother PE-180D support website by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 12, 2010 | Brother Disney PE-180D Computerized Sewing...
Immediately after switching on my washing machine F65, its showing a display PE and is not working.please say me the procedure if any to rectify my problem.do the needful
hello,
what this f 65 code mean is an indication of loose of wire from the sensor reader from the connection
And the PE means that power error that is the loose wire will not allow the washer to carry out is function properly
what you need to do to fix up the problem is to unscrew (OPEN)the WASHER then trace the wire down to the power supply and also the panel connected to the screen clean all form of dirty and water on it fix up the wire that are disconnected from there position .
thank you and thank for using fixay.
Jun 10, 2010 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
