Question about Canon Pixma MX360 Printer
Unable to scan due to error 5,156,61 what i do
I fixed the usb cable but still the problem exists,what is the next more,please help
  • Canon Master
  • 2,013 Answers
I have been unable to access my account all day! the page starts to load then goes very slow and does not open. How can I fix this problem please?
More dtails should be provided on such problems as it may be due to slow connection, errors in browser or may be due to virus attack on computer. Check if the same problem exits with every web page. Try using a different browser. Run a quick virus scan. If problemn still exists please reply soon!
-Ciao
Mar 23, 2011 | Facebook Social Network
I get this error message.. an error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again. Nothing seems to work,, this message...
#Click Start , select Settings , and then click Control Panel .
#Double-click System . The System Properties dialog box displays.
#Click the Hardware tab.
#Click Device Manager . The Device Manager dialog box displays.
#Click the plus sign (+ ) next to Universal Serial Bus Controllers .
#Click the USB Composite Device entry, and then click Remove .
#Disconnect the USB cable from the All-in-One, wait for few seconds, and then reconnect the cable. The New Hardware found dialog box displays.
#Click Next through all of the screens that display while the Wizard installs the USB composite device, and then click Finish .
Regards
Riztech
Oct 24, 2010 | HP Officejet 7310 All-In-One Printer
Sharp MX-6201n get e7-06 error when scanning to thumb drive
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
Oct 08, 2010 | Sharp Office Equipment & Supplies
Scanner error
Hello,well please check the drivers are properly installed if drivers are installed then try to insert the usb cable in other ports
Thanks
Jun 01, 2010 | Samsung SCX-4300 Monochrome Laser...
I have had a hp laserjet 3330 for years and now have an error issue "unable to communicate with device" and despite a re-installation of the software.. the problem still exists. Can you advise?
problem in usb cable , plug the cable direct to the computer not with usb hub or extention cord if don't have solution please check usb port in printer
Jul 08, 2009 | HP LaserJet 3330 All-In-One Printer
'unable to save file. the system cannot find the path specified'
Please check the location where the file saved by your Scanner and note down its size.
Also as you mentioned in your next reply, you need to go for check Device manager. Reinstall the drivers.
Let me know if you need further assistance. Don't forget to vote me.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA MP810 All-In-One InkJet...
O2 xda 2 mini pocket pc usb connection problem
how i get my o2 xda ii mini drivers?
Aug 12, 2008 | O2 Xda II mini
Unable to write to file
I had the same problem and fixed mine without re installation. Even though the error does not indicate it very well, the application could not write to the destination. The EPSON Scan application has a destination in two places. One under configuration, in my case, correct. However, a more buried location, next to the Scan button, press the arrow to edit more settings. There, you will find another destination, in my case, incorrect ( a folder that did not exist). Change the setting to a folder that does exist, it should work. Check out my fix here, detailed with pictures. Thank you. Hope this helps someone.
http://it.megocollector.com/?p=946
Nov 29, 2007 | Epson Perfection 4990 Flatbed Scanner
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Canon Pixma MX360 Printer Logo
201 people viewed this question
old marine
old marine
