Question about Dyson DC33 Multi-Floor Upright Bagless Vacuum Cleaner
Live chat help people
I want to return Dyson Hose Assembly because it had a missing part and it was too small for my Dyson but i want to order a new Dyson Hose Assembly but i want my money back for the Dyson Hose Assembly that im going to return
SOURCE: Dyson not owrking in upright position
I've had this problem. On the lower left side of the vacuum you need to make sure that is completely attached. Pull the part with the arrow button up and push the compartment down. This will allow suction to continue
Posted on Jul 25, 2007
  • 7 Answers
SOURCE: handle won't fasten itself!
I'm no vaccum man but my grandmother ran into the similar issue and all that it was, was she was missing the little look pin that you would push to take it apart, hard to explain but where the handle attachs is there a hole in it about the size of your finger nail? if so then there should be on the handle a little spring loaded button kinda deal, this needs to go through the hole. But if there isn't then sorry for the long blerb
Posted on Jun 12, 2008
SOURCE: on button won't stay on
I had this same issue under the same circumstance. I followed the repair guide for replacing the switch (I didn't replace the switch, just disassembled the switching mechanism) posted here:
http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-switch.html
I found the switch to be stuck in between on and off. I just manually pushed the switch and it became unstuck and started working again.
Posted on May 17, 2009
VacuumRepair
  • 438 Answers
SOURCE: Dyson dc14 will not return to fully upright position NEED HELP~!
Try this quick repair and see if this fixes your Dyson: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it. The suction problem is happening because when the machine is put in the upright position it diverts the suction from the floor to the hose automatically, and it's probably stuck in between the lower part and the hose part.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Posted on Apr 21, 2010
    Dysonteam
    • 167 Answers
    SOURCE: The suction in the hose of my 2 year old Dyson
    Hi there, it sounds as though the wand handle is blocked. To test this, remove the wand handle from the hose and test the suction at the top of the hose. If its strong here, then you will need to remove the blockage from the wand handle. If the suction is still poor, you will need to remove the hose by pressing in the catch on the hose cuff near the base of the machine and removing any blockages.
    I hope that this information is useful to you.
    Kind regards
    Darran
    Dyson Customer Service
    Posted on Apr 27, 2010
    Stiff hose on new Dyson Animal upright
    You need to call Dyson, but bet this is as designed.
    Dec 19, 2016 | Dyson Vacuums
    How to replace dyson part 909545-06 on a doc-15?
    Hi there, it's Jack at Dyson.
    To remove DC15's hose and U-bend assembly, rotate the base of hose downwards until it clicks, then twist away from the machine. The new hose will then attach following the same method in reverse.
    I hope this helps, but if you'd like our experts to talk you through it you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Aug 20, 2014 | Dyson DC15 Vacuum Cleaner Internal Hose
    How to replace lower cable winder ?
    Hi Mani, it's Jack at Dyson.
    DC41's lower cable winder is attached to the hose assembly, and if the cable winder has broken you would need a replacement hose assembly. It's likely your DC41 would still be within our 5-year guarantee period, so it would be worth contacting us directly so we can order this for you.
    When you have a moment, please give us a call on 0800 298 0298 (UK) or 1-866-693-9766 (US) to speak with our experts.
    Jul 16, 2014 | Dyson Shopko DC41 Animal Bagless Upright...
    Repair broken dyson DC08 contact head internal hose
    Hi Vladimir, it's Jack at Dyson.
    The DC08 Contact Head is manufactured and supplied to us as a complete assembly, and therefore we don't have the internal hose available to order separately. If the internal hose is damaged, it would be worth replacing the Contact Head to ensure effective pickup performance. You can order genuine spares directly from Dyson by visiting www.dyson.com
    If you'd like further advice from our experts, please call the Dyson UK customer Helpline on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
    Dec 31, 2013 | Dyson Vacuums
    Cant get the bottom lid of dyson dc7 dirt bin to open
    I am sorry to hear you are having difficulty opening your clear bin. The mechanism that releases the bin base is actually part of your cyclone assembly. When you pull the trigger, a small clip at the bottom of your cyclone releases the bin base. If this clip is missing or broken, part replacement may be needed to resolve the issue.
    You can call us directly to order the the cyclone assembly at 0800 298 0298 (UK) or 1-866-693-9766 (US). The part is also available on our website.
    Best wishes,
    Jessica
    Nov 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    The clip inside the hose for holding the tube (small yellow spring clip) is broken or needs anew one
    I'm sorry to hear you're having difficulties with your DC07. If the wand release button on the hose cuff has broken, the hose assembly will require replacement. If you wish to order a new hose assembly, you can do so by visiting www.dyson.com and clicking on 'Spares'. Alternatively, if you'd like to order by phone, you can get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Online Customer Support
    Sep 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Jul 04, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Dyson DC33 Multi-Floor Upright Bagless Vacuum Cleaner Logo
    16 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
