Sound distortion when playing our recording on play back it distorted
    Problem Solver:
  • 7 Answers
You need to clean the heads! You can just use rubbing alcohol and Q-tips. Just be careful not to have it dripping. It is a good idea to also do the rollers and all moving parts while you are at it. If it has been a long time, do it twice.
If this does not do the trick, then you may need to buy or barrow a tape head demagnetizer. Follow the instructions on it (or google it, if they are missing), as we have all heard of the horror stories of people going overboard and messing things up.
There is the chance that your playback head it messed up in some way. Maybe it has become loose or out of alignment (you may be able to do yourself but I would have a pro do it) or possibly needs replacing. But if you need to replace it, it may be wiser to get a good used one instead (depending on your model).
If you have not used it in a while, it is possible that the belts have stretched. This can be an easy thing to do yourself if you are so inclined but most repair shops do this quick and cheap.
Posted on Jul 12, 2014
    Scholar:
  • 87 Answers
Check 1) Has it ac bias and is the bias correctly adjusted? 2) Are the heads clean? 3) If it has monitor facility is the sound okay? 4) Replace the recording head if all else checks out okay.5) How do the recordings sound if played on another machine? Do this before you replace the heads. What is the condition of your tapes they DO wear out
Posted on Jun 05, 2014
  • 3 Answers
Did you record it too hot?
Posted on Jun 02, 2014
  • Keith McGee
    Keith McGee Jun 02, 2014
robotek
  • 1512 Answers
SOURCE: recording problem onkya model ta2090
check electrolytic caps about the dolby chip. have seen caps (maybe 100uf) go dry and produce problems like this
Posted on Dec 09, 2007
  • 121 Answers
SOURCE: I think the actual tape cassette is the problem
Actually the tape player itself is likely to be causing the problem. Cleaning the pinch roller and tape heads with a qtip and a small amount of rubbing alcohol should do the trick
Posted on Feb 26, 2009
  • 153 Answers
SOURCE: I have distortion of playing tapes.
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Posted on Apr 20, 2009
  • 11 Answers
SOURCE: Hi i,ve got some tapes
I don't own and am not familiar with this device but my advice would be to turn all progs off. As long as you are not on the internet and you have no media connected then turning the anti virus off is safe as your computer is in a stable condition. I would also try using a different usb slot if you have that option as the distorted sound you are describing may be coming from interference with your usb port or cable. Good luck and I hope you manage to record those tapes!
Posted on Jan 05, 2011
Testimonial: "thankyou very much.will give it a try"
skywavebe
  • 1258 Answers
SOURCE: Tascam 122 Mk III - input signal is low and distorted
It is hard to guess what is causing this but for all of the gain to be reduced like that either the deck has seen some really high input signal in the past that blew out some amplifiers or that there is a power supply component that has taken the input electronics down.
I suspect that you will need to have a Technician look at it. If you are near Chicago, I may be your answer, I have been working with these Teac units for 40 years and was a Lead Tech at Chicago Factory Service in Arlington Heights.
I can be reached at skywavebe@sbcglobal.net
If you are far off- I have other people that can do the job one in New Jersey and a few others.
Posted on Aug 18, 2012
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Crosley cr249
are you using a standard microphone jack? like a 1/8" if so this is most likely the problem. also what program are you using. i recommend audacity.
Jun 19, 2008 | Crosley 0187SST Turntable
My camera will play back images but distorts new images
Yes, its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
Jul 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Playback distortion
Good day sir, distortion can be caused by several factors, 1. overdriven audio source, try tuning down the volume to half. 2. the speakers are defective due to driver's coil scratching the magnet. need to replace the speakers, better swap first any good known speakers. hope this may help. if you may have any more questions, feel free to ask again. thanks
Jul 18, 2009 | EMC Zotac GF6100-C-E MCP61P GeForce 6100...
Hi!
It's faulty CCD (imager). Ask Sony if they change them for free there.
Tom
Jul 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Apr 20, 2009 | Audio Players & Recorders
Get bad sound quality after playing a few cd's.
Try Googling (american audio)(MCD 810)(manual) without parens.
Aug 03, 2017 | American Audio Mcd810 Dual Mp3 CD Player...
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Midi playing is
This is specific to AcidPro.
If you doubt, check the same at your friends PC/Laptop.
You will then be sure what i told.
May 23, 2008 | Computers & Internet
Pictures distorted play/record mode
Run the diagnostic software by unplugging the unit. Hold the Play while reinserting the power cord. Continue holding the Play until the diagnostic program is displays NUC XXXX where XXXX is a series of numbers. Once the diagnostics is finished it will pass or fail. To return to normal operation unplug the unit and reinsert the power cord after 15 seconds or so.
Mar 30, 2008 | Philips HDRW720 DVD Recorder
37 people viewed this question
 Grubhead
Grubhead
