Question about Garmin NUVI-255W 4.3-inch Widescreen Automotive GPS Receiver - USB - S
Map Info no detailed maps found that support routing. the nuvi cannot be used without them.
    Habit-Forming:
  • Garmin Expert
  • 184 Answers
If you had lifetime updates you just need to run the latest update, otherwise you will need to but an update to get it fixed. One time should be enough 49.99. Sometimes on sale though.
Posted on Jun 30, 2014
bestdarngood
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin Nuvi 205W tried to download map and now
See the link Here
Regards.
Posted on Apr 16, 2009
RPFinney
  • 385 Answers
SOURCE: Garmin nuvi 205 shows no detailed maps found that support routing
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
this resolves the problem for you.
Regards
Richard.
Posted on May 19, 2009
madguy1089
  • 21 Answers
SOURCE: Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Posted on May 27, 2009
  • 48 Answers
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
Posted on Jun 02, 2009
No detailed maps found that support routing
Please connect your Nuvi up to a PC and look to see if you have the map file "gmapprom.img" in the Garmin directory. The file should be around 1.5 to 2 GB in size. If the file is missing you will need to replace it. If you have registered your unit with Garmin, you may be able to log into your Garmin account and download the map file again. If you can't, then you will need to send the unit to have the map file restored by a service shop. More info on missing maps can be found here:
http://www.sharc.net/gps_lost_map.htm
Apr 15, 2013 | Garmin nuvi 205W GPS Receiver
No detailed mapss found that support routing.The nuvi cannot be used without them.
Check to see if you have accidentally deactivated your units maps. To do this you will have to go into your units tools menu. Go Tools > System > Map > Info check to see if City Navigator is marked . If it is not there you will have to call Garmin assistance and obtain a new copy of your map.
Hope this helps!
Feb 18, 2011 | Garmin nuvi 200W GPS Receiver
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
Everything went dead within 2 hours. The only thing the unit will do is display the following message. - - - - No detailed maps found that support routing. The nuvi cannot be used without them. - - - - -
I would check your map to see if it has a check mark in it.....
Tools.... Settings....Maps..... on bottom of screen Map Info.....make sure a check is in City Navigator North American NT
Oct 30, 2010 | Garmin nuvi 200W GPS Receiver
I tried to update my new Garmin Nuvi 255w. It now reads as follows, No detail maps found that support routing. The nuvi cannot be used without them. I have a ABI and to help me even to get home is hard....
There are 2 possible reasons for this. The most likely is that the map is not selected. Go to Tools, Settings, Map and press Map Info. Is the map ticked. If not press it and it will tick. The map should then work.
The other reason is that the map may be locked. The instructions for unlocking the map are at http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=nuvi%20770
Jul 27, 2010 | GPS
No detailed maps found that support routing the nuvi cannot be used without them
you maps are turned off. go into Tools then Settings. Look for the Map menu. Then Map Info. Make sure you have a check beside the map you want to use. If no map is listed then the next call is the Garmin.
Cheers
Jul 15, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
My garmin just worked yesturday and now reads no detailed maps found that support routing.
check to make sure you have a map set selected ?
settings -> Map --> map info - make sure there is a checkmark next to the map data set (info for a nuvi 350 but it might apply for you)
Mar 18, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI-255W 4.3-inch Widescreen Automotive GPS Receiver - USB - S Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
