Question about Sharp AR-168D Black and White Copier
I have a sharp 1r-168d copier. I have replaced the fuser assembly and now have a H2-00 error. I am unable to enter the servicemans mode to clear the self diagnostics
    Scholar:
  • 136 Answers
That crrect if you do the procedure above you should be ok
Posted on Aug 04, 2009
  • 143 Answers
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
then enter Sim 14 then hit the start button and restart the machine.
Posted on Jun 26, 2009
The fuser assembly light has come on and my copier will not work. It is a Xerox XC1040. Do I need to replace the entire assembly cartridge ?
You can clear the Fuser error by entering diagnostics. Your fuser may need to be repaired though, so your error might return.
Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode. The screen will go blank.
To clear the fuser code, select '14' followed by 'Print', then exit diagnostics.
The fuser 126K07390 has been discontinued but people can sell the sub-parts or rebuild them for you.
Whit Item, Inc.
Nov 12, 2010 | Office Equipment & Supplies
Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Nov 13, 2009 | Sharp AR-C260M All-In-One Printer
Hi, Can someone help with resetting error H2-00 on sharp 168d
H2 00
[Content]
Thermistor open
[Detail]
The thermistor is open.
The fusing unit is not installed.
Cause Thermistor abnormality
Control PWB abnormality
Fusing section connector disconnection
[Check and remedy]
Check the harness and the connector between
the thermistor and the PWB.
Use TC 14 to clear the self diagnostic display.
follows:
Enter 14 Start to clear the code.
Oct 26, 2009 | Sharp AR-168D Black and White Copier
After a power outage my printer is flashing H 4 can you tell me whats wrong? The printer is a Sharp AR-153E
Enter the serviceman simulation mode, press the keys as follows:
Clear → Density select → Clear→ Density select
then enter 14 and hit start. This will clear the H4 (low temperature) code. If you still have a problem, the code will come back. Then you will have to replace either the thermastat (fuse), thermistor or possibly the heat lamp.
Oct 03, 2009 | Sharp AR-153E Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
SHARP AL-1644
To enter the serviceman simulation mode, press the keys as follows:
To cancel the simulation mode, press the clear key. Then enter code 14 then hit start.
Jul 28, 2009 | Sharp AL 1631 Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
H4-00 error on Sharp AR-168D
the code needs to be reset even if you replace the fuser.
Press clear, press *, press #, press * your display should go blank press 14 then press print,
I'm doing this from long term memory I may have the # and * symbols swapped
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Can't get into test command mode
follows:
To cancel the test command mode, press the [CA] key.
H4 00 Content Heat roller low temperature detection
Detail The fusing temperature does not reach 185°C
within 27 sec of turning on the power, or the
fusing temperature keeps at 140°C.
Heater lamp abnormality
Thermostat abnormality
Check
and
remedy
Use TC 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Feb 03, 2009 | Sharp AR-168D Black and White Copier
H4-00 Error Code for Sharp AR-168D
Your Tech is correct in replacing the Unit.
If the Fuser is not reaching the correct Temp it will give the H4-00 Code
The time and money it takes to repair the unit is greater than replacing.
Oredering all the parts for the unit takes longer then ordering the unit.
The only thing a tech can do is clean the Thermistor, reset with sim 14..
If that works, it might work for a hour, might work for days?
I personally carry this Fuser Unit in my car stock as this happens frequently..
Good luck
Oct 22, 2007 | Sharp AR-235 Copier
Sharp AR-168D Black and White Copier Logo
121 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
