Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
I washed the two filters under the canister; foam and cloth filters. Not sure what order they go back on top of eachother under the canister?
    Master:
  • Euro-Pro Master
  • 792 Answers
Hi, it's Ambrai from Crucial Vacuum.
The two foam filters go on top of the felt filter. If you need any other troubleshooting tips, please refer to page 11 of the user manual listed below:
http://www.sharkclean.com/include/pdf/manual-NV22.pdf
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Ambrai Brown
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Posted on May 14, 2014
  • 2,013 Answers
Where do i place the foam sleeve for 5 gal craftsman wet vac
The foam just is put over the round center beneath the top of vacumn with top off the bucket. Just slide up to top of round assembly and you good to go. If you have the paper bag filter on remove it first.
Aug 31, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
How to empty it
1. Push down on carry handle and
pull dirt container away from unit.
2. Once it is pulled back lift it out.
3. Hold dirt container over trash can and push down on bottom
release lever to release debris.
4. Close bottom cover on the dirt
cup until it snaps shut.
While you have the dirt container out you can also clean the Lifetime HEPA filter. It is on the top of the dirt container.
1. Twist lid to the left to remove lid and filter from
container
2. Remove foam filter from dirt container and dump out
any loose dirt. Wash the foam filter.
3. Remove the HEPA filter by Twist filter handle to the left and
pull out of lid. Wash the Heap filter.
4. Once the filters are thoroughly dry (I recommend set out for 24 hours) then installer filters in lid and thread back on top of the dirt canister.
Before replacing the dirt canister you can also clean the exhaust filter install below the dirt canister on the top vacuum cleaner head.
1. Loosen the exhaust grille by pressing the locking tab, and
remove it.
2. Remove and shake out the exhaust filter and wash it.
Note: Scented filter are not washable.
3. Once the filters are thoroughly dry relace it and snap the
exhaust grill into place.
Replace the dirt container
NOTE: Dirt container will not
align on base if filter is not
aligned properly.
May 15, 2014 | VAX Appliances Vacuums
Hi i have a dyson animal allergy and lately when i turn its normal for about 3 seconds and then it makes a large sucking sound its still working ok.but not lifting up as good.its about 5 years old now.any...
Hello :
1: Check that the Dyson's brushbar knob is turned to the "Carpets" setting for vacuuming non-delicate and raised pile carpet. Vacuuming carpet on the "Bare floor" setting usually leaves a telltale single wheel mark on the pile, and pickup is severely limited.
2:Locate the removable filter on the side of the vacuum. It will be marked with a raised circular representation.
3:Press down on the release button with your thumb as you lift filter housing up and out
4:Examine the filter for debris. Wash the blue foam and yellow framed filter in cold water. (See Tips section.) Let dry for 12 hours. Do not wash the outer filter housing that snaps into the vacuum; simply wipe clean with a dry or slightly damp cloth. Replace the filter when completely dry.
5:Locate the airway inspection valve on the opposite side of the vacuum. Press the release button as you lift the valve up and away from the machine.
6:Remove any debris or clogs you find inside.
7:Use a soft cloth to clean up lighter debris and completely clear the airway valve.
8:Tip the Dyson vacuum over to find the U-bend at the back of the unit. Press the release button as you pull the U-bend down and away from the machine.
9:Inspect the U-bend and remove debris. Be sure to line up the release button as you snap the U-bend back into place.
10:Check all removable pieces to be sure they are attached properly and snapped correctly into place. The soleplate should be flush with the cleanerhead.
What you need for this :
  • Large slotted screwdriver
  • Scissors
  • Washcloth
  • Soft cleaning cloths
  • Household surface cleaner, safe for plastics
  • Crochet hook or similar long-handled tool
Warning :
Unplug the vacuum before doing any troubleshooting. Follow all manufacturer's instructions and warnings. The yellow encased filter and blue foam filter pad can be submerged and rinsed in cold water only. Do not use detergent. Do not wash or dry in dish or laundry machines. Do not dry in the oven or microwave.
PLEASE RATE !
Apr 20, 2010 | Dyson DC08 Hepa Allergy Bagless Canister...
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Power switch does not go into high how do we get it out?
I believe it has a foam surround under the top that has the screws which hold the motor assembly on. Also look under the top exhaust connection on the top of the vacuum.
Oct 07, 2009 | Filter Queen Majestic Canister Vacuum
I need to know which way to place the exhaust filter (EF-1) for the Kenmore Progressive canister vacuum.
if its just a piece of foam it don't matter.if it has a cloth covered side the the cloth will be towards the outide of the canister
Mar 20, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Shutting off due to overheating
The foam style filters they sent you go in the top of the vaccume above the canister. There is a sticker in the back of the canister compartment indicating an orange lever in the top of that compartment. This releases a plastic retainer with the foam filter in it. Mine was so caked with dirt after 1 year of use it took a while to clean it up. I thought the vaccume was done for in only a year.
Jan 13, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
My dyson smells bad
Hi.
Yes you can use lots of soapy water & pressure washer or hose to clean the vortex unit but remember it will take at least 36 hrs to dry out internally.
May 21, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
43 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
