Question about GE Kitchen Ranges
How yuo fix oven knob not turning off? - GE Kitchen Ranges
    Problem Solver:
  • 18 Answers
If it keeps turning on the shaft replace it. if the shaft is turning dont use it and get someone in
Posted on Jul 14, 2014
My hotpoint single oven wont heat up.the light will only go on when i turn to knob to light on..but it doesnt come on when i turn the knob for oven on and it doesnt heat up...until yesterday it was working...
Hi there If everything else is working then it's probably the heating element They are not expensive to replace and can be fixed in less than an hr Hope this helps
Sep 25, 2013 | Hotpoint SY36 Style Line Stainless Steel...
What will make a oven come on with the oven knob turned to the off position?
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Jan 15, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
Both oven knobs have come off and although don't appear to be broken we can't seem to fix them back on properly
First try a layer of silver paper around spindle.
If not satisfactory then try a "No nails" type of clue.
Jun 04, 2012 | New World E90DOa Electric Double Oven
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
Old (30 yrs?) tappan gas range.loose oven knob
remove top of range, locate shaft from knob that is loose, there should be a nut where shaft goes into valve, tighten nut in small steps
Sep 17, 2009 | Tappan TGF320 Gas Kitchen Range
Fixing new element into Moffat MSS600.
Yuo can do this from the front those are the only screws so its pretty easy.
Turn off breaker first
Mar 13, 2009 | Ovens
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
