Question about Homelite ZR10926 16 Chain Saw
What is the oil to gas mixture for a homelite cs40?
slohry
  • 87 Answers
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Posted on Apr 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: homelite weedeater smokes
Yes, you have too much oil in the gas.
Jim
Posted on Jun 16, 2009
bbreton
  • 437 Answers
SOURCE: whats the mixture of oil/gas for a homelite
3.2 oz of 2 cycle oil to 1 gallon of regular gasoline, 40:1 ratio.
Posted on Jul 13, 2009
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
dontbother10
  • 2220 Answers
SOURCE: What is the gas/oil mixture for a Homelite Z3300
I cannot find a manual and it is not listed at Chain Saw Collectors Corner http://www.acresinternet.com/cscc.nsf. I did find IPLs and judging from them she is no youngster, based on that I am going to say the manual recommends 32:1 (1 gallon of premium fuel to 4 ounces of quality 2-cycle oil).
If properly adjusted up it will start easier, plugs and the exhaust will take much longer to carbon foul on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
Need to know the gas and oil mixture for a Homelite 2 cycle weed wacker
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
May 22, 2011 | Homelite Garden
I need to know the amount of oil to mix with one gallon of gas for 18 inch homelite chain saw
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
Sep 09, 2010 | Homelite Garden
Oil & Gas Mixture
if you are using sthil oil the mix is 50:1
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is the gas mixture ratio
Homelite products are 40:1 gasoline to oil mixture
May 24, 2010 | Homelite Mighty Lite Lawn Trimmer
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Oil mixture
50:1 the little bottles make 1 gallon of mix gas
Apr 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Need oil gas mixture for homelite HB 100 blower
Apr 12, 2009 | Homelite Consumer Products MightyLite...
Homelite ZR10926 16 Chain Saw Logo
66 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
