Question about Home
Im fitting a moretti quadrata shower, valve is fitted inside the wall and all tiled but cant fit the rose?
Mixer fitted inside a stud wall and tiled with a 15mm stab thru for rose, but the pipe wont hold the weight of the rose and cant fit as theres a thread then the cover, no bracket, any ideas?
4 Suggested Answers
  • 10865 Answers
SOURCE: how do i fit an electric shower to a tiled wall
You may be access the pipes from the other side of the wall containing those pipes. so rather than have to cut into your tiled wall, you will be cutting into whatever is on the other side of that stud wall.
Posted on Feb 17, 2009
ffrn99
  • 6 Answers
SOURCE: Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Posted on Mar 09, 2009
  • 158 Answers
SOURCE: Have a Delta R10000 Faucet
You should have a template in the kit for this. The web site will also have detail specifications.
Short of that (and I've been there) use a piece of cardboard. Trace the outside edge. Now make in inner circle the width of the flange area. Cut out the remaining center. Align it to the shaft on the wall and mark your cut line. Some of these have a single screw that attach the cover to the hardware in the back. Being a thin wall you may need to set back the plumbing tree to get the cover all the way in. If you are soldering the fittings be sure to remove the nylon sleeve first as the heat can damage it.
Posted on Apr 14, 2011
Seem to have water leaking under shower into storage competition ment, tried caulking only happens when shower is on and someone is in it very frustrating
Very often happens for a number of reasons
Bad caulking around the shower base and the base drops with the weight of the occupant allowing water past the caulking.
Crack and bad seal on a wall tile.
A split in the base itself which opens up with weight and you can't see with the base empty.
A leak in the pipes behind the wall from the mixer unit to the shower head.
Split pipes or fitting to the drain.
Best way is a full tear down, refurbishment and start anew :>)
Jul 10, 2016 | Home
I've just installed a grohe mixer shower/bath
Did you account for wall thickness?
Dec 17, 2012 | Water Heaters
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
My thermostatic mixer shower will not turn off
he probably put it together wrong.
there is usually a blue gasket inside for testing purposes, if that is not removed, the valve will not turn off.
May 12, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Im fitting a 1200 x 800 shower tray but having problems getting old one out same size,its in an en-suite, tray just a bit longer than room, dont want to break tiles thats in cant replace them any ideas
well if the old one wont come out,,, then the new one wont go in,,,as its the same size,,, looks like you will need to risk them tiles to me, even if you cut the old one out, you cant cut the new one back in can you?
so its back to them tiles, go on, risk it!!!
Oct 23, 2009 | Dreamline SHOWER ENCLOSURE TRAY Right...
There is virtually no water flow from the shower faucet we have just plumbed in. there is plenty of water pressure to the sink which is on the same lines. is there anyway to take off the thermostatic...
shower heads are fitted with a 'flow limiter' which is no more than a washer under the sealing gasket where the 'head' fits to the supply pipe.un-screw shower head from pipe,remove 'limiter' reinstall & enjoy.
Oct 17, 2009 | Pegasus Technologies Plumbing
Replace old vinyl/plastic type stand up shower - I want to convert over using tile. What do i use as a bottom pan i can tyle over?
You could make a base that would be framed up 2x4's and covered with a waterproofing membrane. lay concrete floor, sloped to drain (2piece) and tile. Or use a fibergass base that fits to studs. And then tile walls.
Sep 21, 2009 | Home
How do i fit an electric shower to a tiled wall
Feb 17, 2009 | Home
Installation Rules?
There are four golden rules for installing a shower enclosure. The first golden rule is to make sure that the shower tray is level. If it is not, then problems will occur throughout the rest of the installation. Use a good quality spirit level and where possible install a tray that has adjustable legs. There are often problems associated with tiling over upstands as some are thick and difficult to set into the wall. The second golden rule is to install a tray that has a slim tiling up stand which is vertical and an integral part of the tray: This will make the installation easier, quicker and ensure it is totally watertight. Before installing the shower enclosure the third golden rule must be followed. A silicone sealer needs to be applied all the way around the join where the tiles meet the tray: This must be sealed first, to ensure there is no chance of water getting behind the wall channels and then into the walls. This is one of the biggest problems associated with shower installations but is easily solved if the silicon sealer is applied before the enclosure is fitted. The final golden rule is to fit the enclosure to the tiled surface and not on to a plastered wall, tiling up to it afterwards. Having installed the enclosure it is essential to use the same high quality silicone sealer around the outside of the enclosure. Sealing on the inside will cause leaking- not prevent it.
Aug 27, 2008 | Dynasty Hardware Pacific Shower Basket or...
Fitting Electrical Shower -electrician will do final connection at consumer unit
Sorry,
Thought the service was free
Silly me, only found out it wasnot after I had typed the questioin and thought it would then be aired on the forum anyway
Thanks anyway,
Roger
Jul 31, 2008 | Kitchen Appliances - Others
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
