Question about Zanussi Washing Machines
On/off switch will come on but nothing else will happen
Fuse blew before problem,
  • Bassa Skinn May 14, 2014
    water available,door closing ok,
    no i think it's either a heater short, a card problem or a motor fault
    New Friend:
  • 102 Answers
If you have a breaker you might try shutting it off then back on. That could be the problem
Posted on May 14, 2014
Nothing happens when the ignition switch is turned on
You should not change the wattage on bulbs as the increased load may wreak such havoc with your electrical system.
I would wonder that the main fuse would blow, do you have any power to anything?? Maybe you blew a lighting fuse.
If you find the solution please make a comment and post it.
May 09, 2014 | 2007 Harley Davidson FLSTN Softail Deluxe
Blew a fuse now amp wont power up
It must go to a repair shop. There's always a reason that a fuse blows.
Jan 28, 2014 | Marshall Mg100dfx 100-Watt Combo Guitar...
Brake lights troubleshooting
Hi Tanya, A short circuit in a vehicle is very dangerous. The cause needs to be identified and isolated. Why did you replace the brake light switch and then the indicator switch? Did the fuse blow when operating those units? Let me know more information and maybe we can sort it out? Regards John
Oct 26, 2013 | Cars & Trucks
My York Pacer 3500 Treadmill switched on then every time I used it the fuse blew. Its happened almost 5 times.
see the block diagram attached.
1) you must test the power cord for short wires.
2) test the power switch for short.
3) test coil for shot
4) test capacito for short.
5) the main motor board can be faulty
In short you must disconnecat every wires , and isolated the short for to avoid the fuse blown.
Otherwise you must call some service tech, from your supplier company.
God bless you
Jun 29, 2012 | York Exercise & Fitness
I have a cub cadet 2165, it was running great, turned it off-nothing happens when I try to start it, no clicking, nothing- checked battery cables-tight, checked for broken or loose wires-nothing-HELP
Hi
You blew a fuse. The easiest fuse to get to is under the hood and next to the gas tank. Replace it with the same fuse. Make sure the tractor is in neutral, blades are not engaged and the brakes are set. Should start right up. If not, you've blown a different fuse or a switch has gone bad. A reputable repair person is needed then.
May 20, 2010 | Peg Perego Cub Cadet Tractor
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Sharp AR-336 copier was moved, now it will not power on
no, its possible you blew an internal fuse in the machine. only one power switch.
Jan 22, 2009 | Office Equipment & Supplies
Fuse
If he means the cables were put on backwards, you probably blew your 100A battery fuse.
If absolutely nothing turns on and nothing happens, thats most likely what you blew.
Its located in the under-hood fuse box. Its the biggest one in the box and you'll need an 8mm socket or a philips head, but I would recommend the socket. Those bolts are tight.
Aug 06, 2008 | 1992 Acura Legend
Duet Model GEW9200LW0 Dryer will not start-Code 3E
I have a GEW9200LW0 whirlpool dryer, that displays 3E when I try and start the dryer. nothing happens,All i get is the 3E code.
Dec 08, 2007 | Dryers
Washing Machines Logo
80 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
