Question about Vehicle Parts & Accessories
How to remove the climate control display from a 2004 Buick Park Avenue?
The display does not light up and I need to know how to remove it for repair.
  • 3 Answers
This is a very common issue, and fortunately the repair, although time consuming, isn't difficult.
Pop the top of the console (not the woodgrain part) off, disconnect the trac control button and lay aside. Remove the rubber mat on the bottom of the storage compartment. Remove the two 10mm bolts in there, the two to the rear of the shifter and one on each side of the very front end of the console by your feet.
Remove the ashtray, then carefully work the console rearward enough to get the climate module out, 1997 03 Buick Regal climate control display repair part 1
Posted on May 25, 2014
Climate control lights dim
It looks like the entertainment center and climate control bezel should be removable, w/out pulling the dash. You can get a diagram from your dealer's parts dept.
Mar 19, 2014 | 2007 Buick Park Avenue
99 Buick Park Avenue, climate control turns temp up by itself.
It takes special equip to diagnose this problem, so off to the dealer with you on this one.
Oct 09, 2012 | 1999 Buick Park Avenue
Need to find heater blower resistor on 1991 Buick Park Avenue
GM: Electra/Park Avenue/Ninety-Eight 1990-1993 REpair Guide
Blower Resistor Module
Fig. 1 Blower resistor assembly is underneath the fuse block
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the rear sight shield.
  3. Remove the fuse/relay block assembly and bracket.
  4. Disconnect the resistor module connector.
  5. Remove the retaining screws and remove the resistor module.
To install:
  1. Inspect the gasket and replace or repair as required.
  2. Install the resistor module and secure with screws.
  3. Connect the resistor module connector.
  4. Install the bracket and fuse/relay block assembly. Install the sight shield.
  5. Connect the negative battery cable, and check the climate control system for proper operation.
Hope this help (remember rated and comment this).
Mar 29, 2010 | 1991 Buick Park Avenue
1995 Buick Climate Controls Going Crazy
Same thing happened with my 95 park avenue a few weeks ago. I talked to a guy I know who is a GM mechanic and he says that the module (the thing on the dash with all the buttons and the temperature display) is broken and needed to be replaced. These computer modules just get funny with age and eventually have to be replaced. You can find one pretty easy on ebay motors. It's not hard to replace, you just have to take apart the dash and take out the old module and put the new one in. Hope this helps!
Mar 25, 2010 | 1995 Buick Park Avenue
No air conditioning, flashing climate light
You should make sure you have proper charge for sure.has your battery gone dead lately? I know on some of them digital climate controls will act exactly like this and have to be reset or go through a setup sequence.
Aug 13, 2009 | 1994 Buick Park Avenue
1996 Buick Park Avenue - HVAC doesn't turn off even with key out
You need a blower control module ... located under the relays and fuses on the firewall.
They run about $150.
Nov 04, 2008 | 1996 Buick Park Avenue
Vehicle Parts & Accessories Logo
114 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
