Question about HP LaserJet 3330 All-In-One Printer
I have labels stuck and now paper stuck to the label and I figure out how to get to them. It on the black roll thing
  • HP Master
  • 1,684 Answers
The black roll thing is the fuser roller. If you have a label stuck to this unit them it will need to be replaced. The fuser roller that you see has a coating of teflon and if a label is stuck to it, the coating will be damaged when you try to pull off the label. The HP part number you need is RG9-1493. Check with your local printer repair shop for pricing, If they can't get you what you need check Ebay.com We have service manuals for his unit available for $6.95 for a download if you need one. The manual is at www.ccl-la.com/hplj3330.htm The service manuals have disassembly instructions, parts lists and troubleshooting tips.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jun 25, 2009
Replace the roll without black on white in DYMO 450 turbo
Most of the labels come with the black rolls already in place
i think you can just reposition the new labels on an old roll if the end isn't attached to the roll
Mar 14, 2014 | Dymo LabelWriter 450 Turbo USB Label...
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
Can not reload lables in the gun
Depending on the type of gun that you have, loading will vary. Here is the most common style of label loading:
Loading
  • At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
    Insert a roll of labels into the gun opening so that the beginning of the roll is at the back and comes up over the top of the gun. Insert the beginning of the roll into the slot, squeezing the trigger halfway. Push the labels through the gun until they come out at the front. Thread the labels up and under the black plate on the front of the gun and then under the rubber roller. Squeeze the trigger again and pull six or seven labels out. Discard the labels, leaving the paper backing. Thread the paper backing into the underside of the gun, next to the handle, in the direction indicated by the arrow. Push the paper backing while squeezing the trigger until the gun begins dispensing labels.ixzz18ERFHy
  • Dec 16, 2010 | Office Equipment & Supplies
    How do I load labels in monarch 1100 price gun
      Loading
    1. At the back of the pricing gun, there's an opening with two spindles to hold a roll of labels. There's also a slot and two small, black rollers, where you'll place the first label to begin feeding them into the gun.
      Printing
    1. If the print on the labels is off-center, place a penny in the slot on the right side of the gun and hold it in place. Using another penny, turn the adjuster on the left side of the gun in a clockwise direction, printing test labels to check your correction. Keep turning the adjuster until the print is centered.
      To replace the ink cartridge, turn the latch on the right side of the gun to an upright position. Pull the door out. The ink roller is on the end of the door in a plastic holder. Push the holder apart slightly to remove the old ink roller and insert a new one. Replace the door and turn the latch to hold it in place.
    Nov 29, 2010 | Monarch ® Pricemarker 1110 One-Line...
    Changed rolls of labels on Zebra GX 420T and now nothing prints
    Were the new labels thermal paper? Thermal printers need specially made paper to work right.
    May 28, 2010 | Zebra LP 2844 Thermal Printer
    Label stuck under typewriter platen/roller of Adler Royal
    Roll a new piece of paper the best you can. Dribble a little paint thinner on the paper, letting it run down under the roller. The thinner will disolve the adhesive on the label. After a couple minutes, you should be able to roll out the paper and the laber with no problem.
    Aug 28, 2009 | Office Equipment & Supplies
    I use direct thermal paper with a black mark at
    Compare the 2 rolls, Pay close attention to the position ans size of the black mark. The black mark sensor in the zebra 2844 is not (where you would expect it to be) in the centre of the label. It is about 10mm to the right,
    Try calibrating the printer to your labels.
    Check my other solutions to see how to perform a manual calibration.
    Jul 29, 2009 | Zebra LP 2844 Thermal Printer
    Remove a label stuck to the metal floater behind the pleten myself
    Take a quarter piece of typing paper. Soak it in paint thinner. Roll this down where the label is stuck. The paint thinner will dissolve the adhesive on the label but will not harm anything in the typewriter.
    Apr 24, 2009 | Brother ML-100 Typewriter
    QL-550 Label Stuck
    Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
    Apr 24, 2009 | Brother P-touch QL-550 Thermal Label...
    HP LaserJet 3330 All-In-One Printer Logo
    169 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
