Question about Garden
Countax C300H running problems
The engine revs up and down by its self but runs fine with the choke left on? what could be the problem
    New Friend:
  • 102 Answers
Carb jets probably need to be cleaned
Posted on May 14, 2014
  • 109 Answers
SOURCE: starts on choke but dies when moved off choke
If it will start on choke and die when choke is taken off...the carb needs to be taken off and cleaned. The main jet in the carb is probably clogged.
Posted on Apr 21, 2009
  • 168 Answers
SOURCE: blades not cutting checked all belts they are ok
Either the belts are worn making them too loose, or you may have a spindle issue there. Check the spindles to make sure they aren't seized. Also, check the blade center nuts to make sure they are tight. Good luck.
Posted on Oct 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: engine starts well but runs only with the choke
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 15, 2010
SOURCE: My countax C300H starts OK but when I engage the
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Posted on Apr 21, 2011
  • 87 Answers
SOURCE: mower runs with choke on turn choke of rev up and
You have a dirty carb, start off by cleaning and draining your carb and your fuel tank, remove the fuel bowl on your carb and use a spray can of carb cleaner to clean the tank and carb bowl. be careful not to ruin or loose the orings that seal the carb bowl,,put it back together with fresh gas and you should be ready to go for the summer. always be sure to add fuel stabilizer to you fuel to keep your gas from going bad and gumming up your carb,.. You can get the stabilzer at any parts store even wal mart has it it the automotive section of the store..
Posted on May 26, 2011
Automatic choke problems
check the charging capacity of your alternator.
Mar 10, 2014 | Mitsubishi Pickup Cars & Trucks
My honda cb750f will not run without the choke being out
Vacuum leak.
Check all mating surfaces, any place where a vacuum line attaches, with a short spray of carb cleaner while running, when you find the leak, it will smooth out and speed up on it's own. And if EGR equipped- make sure the EGR is closing fully when cold and when hot at idle.
Jun 01, 2012 | Honda Motorcycles
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Countax C300H Garden Tractor Manual
I have a countax 300h about 8 years out Will not start and a warning letter C is lit up any ideas what is wrong
Apr 04, 2012 | Garden
I have a kawasaki250gpxr.when i put choke on it starts up but when its warm and i take choke of it will high rev tjhen die on tick over ,but the bike rides fine
Sounds like running lean fuel condition running with choke on high rev when choke off and cutting out all points to lean condition
Get it serviced and tuned if you not confident to adjust fuel mix your self also you could try some fuel cleaner additive to your fuel tank that may clear it if is just dirty pilot circuit you might get lucky
But I would suggest get it serviced and tuned some where you trust ASAP you wont hurt anything it will just let you down when you need it AS THEY DO!!
May 22, 2011 | kawasaki GPX 250 R Motorcycles
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there...
Mar 26, 2011 | Honda Garden
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
MY 89 TOYOTA COROLLA 1.6 AUTO MATIC TRANNY CARB MOTOR ACTS FUNNY WHEN I TURN THE KEY OFF . IT ACTS LIKE ITS CHOKING OR SOMETHING .KEEPS IT UP FOR A COUPLE SECONDS ONLY THEN DOES TURN OFF ? ALSO WHEN...
It's called dieseling and it's caused by the self ignition of the fuel in the cylinder because there's a lot of carbon buildup in it. You can either dismantle the engine or use a specialized fuel additive to clean it.
Aug 19, 2010 | 1989 Toyota Corolla 2 Door
My 2006 yamaha v star 650 will run with choke on but will not rev . the engine will not run at all with the choke closed . if you cover the air intake it will rev
You have a vacumm hose loose look for small hose no connecter to anything - should solve it - I had a similar problem with a ZX9r the other day - same would run fine on choke not idle or start without it
Good Luck
Del
Jun 29, 2009 | 2006 Yamaha V Star Classic
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
