THIS MESSAGE : (SYSTEM ERROR ) SERVO (CARRIGE) E-2 OVER LOAD
Wep hq 2000 printer carrige error
wipro hq 2000 printer in carrige error
May 02, 2012 | Office Equipment & Supplies
My Panasonic NV-SD250 VCR displays FO4 message. The unit refuses to eject tapes.
Possible fault with the failure of the servo system, the mechanism , front loading and forward loading or the failure of the drum servo/capstan servo.
You can remove the front panel and top panel and remove up the loading mechanism by unscrewing the mounting. carefully disconnect the cylinder head strips, the audio connections and remove. manually turn to unload off the tape. then check for belt failure or visible errors. Now set back use a dummy cap to cover the end sensor emitter at the centre and manually push the loading mechanism assisting . If there is no loading the capstan is faulty, if it loads and the drums does not work it is tthe cylinder servo.
You will need some knowledge of the circuits to proceed to the correct fault.
Sep 01, 2010 | Panasonic Televison & Video
Error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
Mar 22, 2010 | Sony DSR-1500 Mini DV VCR
Carrige Jam
carriage assembly defective..uneconomical to have repaired. Sorry
Jan 26, 2009 | HP PSC 2355 All-In-One InkJet Printer
Canon MP150 - Error - E,2,2
My ink cartridges are "stuck" on the far right side & not accessible. Any help would be GREATLY appreciated.
Nov 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Ac servo drive Errors
seus burro
Jun 17, 2008 | GPS
Pixma ip8500 - error 5C00 A problem has occurred with the printer mechanism.
printer mechanism misalignment during travel
problem may be {cartridge , carrige block , service station, or encoder strip}
Feb 28, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Error message
OPEN TOP COVER CLEAN ALL RUBBER PAPER FEED WHEELS WITH RUBBING ALCOHOL APPLIED TO A MICROFIBER TOWEL.
THEN LOOK AT CARRIGE BAR THE BIG SILVER BAR THAT INK CARTRIDGES RIDE ON APPLY TWO OR THREE DROPS OF 3 IN 1 OIL AND TOP THE TOP OF IT AND RESTART PRINTER
Jan 17, 2008 | Epson Stylus Photo R340 InkJet Printer
Dell 922
TRY UNPLUGGING PRINTER FROM WALL AND PLUUGING IT BACK UP allow cartridges to unlock lubricate you carrige bar with 3in 1 oil while it is off the carrige bar is the silver bar the ink cartridge assembly travel along use only two or three drops of oil.
Oct 07, 2007 | Dell 924 All-in-One InkJet Printer
14 people viewed this question
k24674
jasbo
jasbo
