Question about Orbit Sprinkler System Super-jet 3-inch Pop-up Impact Canister With 35
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
I tried to adjust the plastic ring things right below the head. It seems to kind of work but not how I need it to..
    Problem Solver:
  • 11 Answers
I agree. Replace that head. They are junk
Posted on Jan 11, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 71 Answers
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
Posted on May 16, 2014
I just bought a 4-12x40 trophy xlt rifle scope with an adjustment of numbers on the bell. What is it?
That is a parallax adjustment. You set it for the distance you are shooting at. It appears to be marked in both yards and meters. This adjustment assures the reticle does not appear to move when your eye is moved slightly from side-to-side. Set it for 200 and look at a target at 50 and move your head very slightly side-to-side and you will see the difference.
Sep 17, 2014 | Bushnell Trophy XLT Riflescope 4-12x40...
How adjust distance
Turn the sprinkler on. Go to the sprinkler and at the center of the pop-up nozzle you should find a screw.If the screw is there, it can be tightened or loosened to adjust the spray distance.
Jun 21, 2014 | Orbit Irrigation 54196 400 Series...
I have a Nelson Pulsating sprinkler and can't figure out how to make it go all the way around
See if the stop that makes the sprinkler reverse by hitting the adjusting rings can be lifted up so that it doesn't hit the adjusting rings.
Gary
Jul 22, 2011 | Nelson Garden
How do I get the sprinkler 'T'' HEAD off
Hold the plastic nut located just under the "T" with adjustable pliers or wrench and unscrew the "T head" with your hand.
Mar 14, 2011 | Nelson Sprinkler: Traveling Tractor
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Impulse sprinklers stick after cloclwise rotation; no return
i wouldbet it is a pressure related problem , can you isolate them so you are only running 1 at atime? at least reduce the number of sprinklers running at the same time just to test them, drop the number by1or2 and i`m sure your problem will be fixed youdoit
Jul 22, 2009 | Orbit Sprinkler System Power Source...
Hunter sprinkler head adjusting...
I googled Hunter sprinkler heads and where to purchase them. In my area (the East bay, Tri-Valley) in Nothern California.
I went to Ewing Irrigation in Dublin, CA and found the Hunter sprinkler heads there. The man working the counter got two for me and he demonstrated how to change the head by unscrewing it from the base at or just below ground level by removing the old one and screwing in the new head. He also showed me how to adjust them with the spray pattern. You will need the little tool that comes with the sprayer head.
Making sure the center arrow is completely to the left and rotate the head to the right then back to left. They are set to a 180% spray pattern from the manufacturer. If you want a bigger pattern you turn the adjuster toward the ( + ) side and if you want less pattern you turn the adjuster to the ( - ) side. He showed me how to install the red sprayer inserts by simply pushing them in the cavity making sure the little u shaped indentation is pointing up to allow for the set screw to go through to adjust the spary.The spray varies in distance and amount of water being emitted from the head depending upon the insert used.
I was able to replace the Hunter head, adjust the spray and changed out the insert a few times until I found the one I liked. I used needle nose pliers to remove the initial spray insert that the man @ Ewing installed until I found the one that worked best.
I found using needle nose pliers makes it very easy to grasp the little inserts for replacing.
-Terry
Apr 04, 2008 | Ace Hardware Hunter& Low Profile III...
Orbit Sprinkler System Super-jet 3-inch Pop-up Impact Canister With 35 Logo
511 people viewed this question
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
