Question about Xerox Office Equipment & Supplies
How to reset drum counter
Xerox 7545 workcenter
  • 33 Answers
There is no way to do that. Usually the drum goes very scratchy in this model before the designed life has passed.
Posted on Jun 25, 2014
  • 1056 Answers
SOURCE: how to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Aug 28, 2008
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  4. close front cover
Posted on Mar 23, 2009
  • 2072 Answers
SOURCE: I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
Posted on May 04, 2009
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Posted on Nov 03, 2009
Testimonial: "Fantastic! The code for the Sharp AL-1644 drum reset worked like a dream! Thank you."
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
Xerox 7120 error code 093-320 reset
bonjour j'ai un code erreur sur ma xerox workcenter 7125 je trouve pas de solution si qlq px m'aide merci d'avance code 093-320
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
Hi, I have a Workcenter XD102. It gives me a J2 error. I don't know how to fix it. Please help. Thank you very much, Charles
J2 error for Workcenter XD102 indicates a Drum Cartridge Problem sensed by the main PWB indicating that the Drum cartridge had reached its end of life. You may replace the Drum cartridge with a brand new Drum Cartridge. This should fix the problem.
If you believe that its not the Drum cartridge with or without replacing the Drum cartridge, you may try to open the printer, make a good clean and perform the below. 1. Check the PWB and Drum Cartridge Reset Circuit for any loose connection and short circuit. You may re-seat the cables and terminations and test. 2. If that didn't work you might need to get some voltage from the Drum Cartridge Reset Circuit as per below. 2a. If voltage is more than 0.5 VDC measured between PJ CN116-2 and GND then you need to replace the Drum Cartridge Reset Switch PL x.x. 2b. If voltage is less than 0.5 VDC measured between PJ CN116-2 and GND then actuate the Drum cartridge Reset Switch. Then check the voltage if its +5 VDC measured between PJ CN116-2 and GND. i. If not then replace the Drum Cartridge Reset Switch PL 5.. ii. Else it should be fine. iii. If not then replace the Main PWB, PL 7.1.
Jul 12, 2011 | Xerox WorkCentre XD102 Printer
Xerox ws m24 drum counter reset?
how we can reset counter of drum unit m24
Nov 20, 2010 | Xerox WorkCentre M-24 Color Copier
Jul 24, 2009 | Office Equipment & Supplies
How to reset drum counter for fuji xerox 203A
Aug 28, 2008 | Office Equipment & Supplies
162 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
