Question about Riso Office Equipment & Supplies
How can I repair my Riso KS600/KS800 error code E13?
SOURCE: error code E4 for riso ks800
riso ks 800 error code c-7
Posted on Oct 20, 2009
  • 5 Answers
SOURCE: Any procedure to change drum in riso ks800
open the front casing of the machine 6 screws. then pull of the power supply, also the the main board of the machines then, at the back of the machines, open the case and pull out the harnest that attached on drum. then unscrew the ink hub,, then unscrew the drum from the chasis , dont forget the harnest of the position A, to pull out.
Posted on Jul 27, 2010
  • 167 Answers
SOURCE: Shows me E13 code error
try to pullout black cartridge then put it back again and or the cartridge need a reseter and or it's empty
Posted on May 25, 2011
SOURCE: riso ks800 j5 error... help me
erreur j9 en riso ks 800
Posted on May 28, 2011
  • 3 Answers
SOURCE: riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Posted on Jul 12, 2011
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
CODE E4 RISO KS800
ink overflow --inside the printing drum there's a small circuit with two pin ( like needles)....there is one shorter than the other, they are very thin... you have to clean them with a small swab and alcohol, be very carefull, don't bend them....hope this be usefull to you :)
Dec 22, 2013 | Riso RZ390 Duplicator
Bonjour, ma riso ks800 marque l'erreur de E4 .Pouvez vous m'aider pour la resoudre SVP? merci d'avance!
HI. E4 REFERS TO "INK OVERFLOW" . CHECK INSIDE THE DRUM, AND CLEAN IF NECESSARY. IF YOU NEED MORE INFO, LET ME KNOW :)
Apr 16, 2012 | Riso RZ390 Duplicator
Shows me E13 code error my ks800
May 25, 2011 | Office Equipment & Supplies
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
Ks 800 Riso Digital duplicator Machine my Machine problem is E 3 code (sir plz Answar )
que significa el codigo de error e13 el riso ks 800 y que devo hacer para slolucionar el problema
Feb 04, 2011 | Riso RZ390 Duplicator
Help me
clamp error.
Apr 07, 2010 | Riso RZ390 Duplicator
Error code E4 for riso ks800
Dec 06, 2008 | Riso RZ390 Duplicator
Riso ks800
Sep 21, 2008 | Office Equipment & Supplies
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
