Question about Frigidaire Washing Machines
Frigidaire crown washer user manual
Need to change it from 110 V to 220 V to make it working overseas
    Genius:
  • 1,554 Answers
Unless the model number tag says it can do 110/220 (on the tag) then you don't want to try this it will require a heavy expensive transformer ,wasting some of your power every time you use it.
for a manual , i could not find crown so youll need to look here.
http://www.frigidaire.com/Washers-Dryers/Washers/
Posted on May 19, 2014
Crown series. Why isn't it advancing to spin cycle?
Hey Chuck, thanks for your inquiry!
Based off the information you have provided your Frigidaire washer is not advancing into the spin cycle. You could be experiencing an issue with your timer or wiring harness. I would suggest performing a reset on your washer to help clear out any possible miscommunication that may be within the appliance. You can reset the washer by flipping the household circuit breaker off for at least ten minutes. I hope that this information is helpful to you in some degree. -Matt
Mar 28, 2016 | Frigidaire Washing Machines
Dimensions for the Frigidaire Front Load Washer FTF530FS3
For a normal install, the washer is 36" H x 24 3/4" D x 26 3/4" W. If you install the washer under a counter with the top sheet, then it needs 34 5/8" to the bottom of the counter. The dimensions are given in the installation guide available from Frigidaire or Sears Parts Direct. See https://secure.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/user-manuals/manual-downloads/Model-FTF530FS3/1428/0153200?modelNumber=FTF530FS3&diagramPageId=&documentId= . A direct link to the Installation Guide is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/INSTL/L0709314.pdf . See page 3 with the Rough-In dimensions.
I hope this helps.
Feb 24, 2016 | Frigidaire Washing Machines
I have an Affinity Washer model #FAFW3801LW3 I need to change baffle in the tub. Do the screws line up so I don't have to take the outer tub off to remove baffle
I appreciate your post, Doug!
I see that you need to change the baffle in the tub of your Frigidaire washer, FAFW3801LW3, and you would like to know if the screws line up. Based off the parts manual it appears that the screws line up. I have included a a copy of your parts manual for you to review. I hope this information is helpful to you. -Matt
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=FAFW3801LW3+&User=&Search=Search
May 23, 2015 | Frigidaire Washing Machines
What is the capacity of Frigidaire washer GLTF1670ASO?
dont you have your frigadaire user manual
http://www.retrevo.com/samples/Frigidaire-Washer-manuals.html
tell us if you cant find the answer
most problems are caused
by user who dont defrost totally for like 4 days
then clean and restart
and failt too clean the eveporator trays and tubes {not for users for a tech}
if your not sure always ask for professional help
however cleaning the pipes and tubes and V shaped water guides
esp behind the back of the freezer cab
esp if the botton freezes and the whole cab doest
then the blast fan may have failed
Mar 05, 2015 | Frigidaire Washing Machines
Frigidaire Crown Washer #CRWS5700ASO won't fill with Hot or Warm water.
Clean small Filters...in THE WASHER Inletts.,Check for any clogging also.,inside THE HOSES.
Feb 21, 2013 | Frigidaire Washing Machines
How do you access the water pump on the frigidaire crown cws3600as washer?
You pop the spring clips and raise the top then remove the front. I have your repair manual: HERE
Jan 13, 2010 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
