Question about HP 6700
Faxes are not going though to distination. Phone line is plugged into fax machine
    Master:
  • HP Master
  • 630 Answers
  • 163 Answers
SOURCE: Fax shows an 'off-hook' status
pleaz check the hook sensor
Posted on Sep 16, 2007
  • 5 Answers
SOURCE: set up fax and dsl using one phone line
You can buy a splitter to put on your line so you can run both devices. They sell them at the dollar tree big lots and everywhere else usually, and range from .59 to $2. as far as another DSL filter ask a friend neighbor or co-worker if they have or had dsl and have an extra filter. If not then you can pick them up for a couple of bucks at radio shack
Posted on Feb 21, 2009
SOURCE: Hp all in one 5610 wont receive fax and phone
geeting error 322 masage when faxing
Posted on Jul 17, 2009
SOURCE: My HP M1319f fax machine is having trouble sending
I have purchased the HP M1319f multipurpose machine 1 year ago and expected it to print as well as fax. Sadly to say 1 year later, the printing works as expected but the fax never worked consistently for me. The solution I found was to buy a used fax machine and only use the HP M1319f as a printer.
The problem I've read about this problem on HP forums was the fax speed of the M1319f. It is locked to 28.8k which means it is only able to communicate with some fax machines. Older machines that doesn't support 28.8 will get errors and the fax will fail. This is definately an HP problem but considering I purchased this 1 year ago, this problem will never be fixed. Avoid this printer at all costs if your considering to use the fax machine.
Posted on Dec 28, 2009
  • 223 Answers
SOURCE: HP LaserJet fax not working
Hi Steve,
This could be one of a couple of things,
!. Digital Phone lines that are not filtered, this printer has an analog fax card, if you are on digital phonelines there is too much noise for the printer to recognize the data and connect to the sender. Try setting the error correction mode to off, this should be an option under the fax setup menu, also if you see the option for fax speed make sure it is set to v.17 or medium. If this does not work contact your service provider and ask to the test the quality on the line, If your fax can send faxes it more likely to be static or noise rather than a hardware failure, You can also try doing a hard reset which will reboot the fax card, I believe for this printer the way to do so is the following: while the printer is off hold down the right arrow and the cancel button and turn the printer on, Hold unitl you see permanent storage init,
It wouldn't hurt to check if there is a firmware update available,
Al
Posted on Jul 16, 2010
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
Intellifax 4750e phone and fax line stays open, no dial tone
Is the fax machine on? (Are the lights or screen lit up?) Make sure that the line going from the fax machine to the wall jack is plugged into the LINE port on the fax machine, and not the TEL port.
Try plugging a regular phone into the wall jack where the fax machine is currently plugged in... do you get a dialtone? If so, the problem is either with the fax machine or the way it is configured.
May 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
The fax will not answer even though I have it set to answer after 2 rings. It is on a dedicated line. Help!
There is a check box that must be checked in order to enable automatic answering.
Also, you have to have the phone line plugged into the Officejet machine
Oct 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Can't receive faxes, I can send faxes and print reports though. messages says "Receiving Error - ask sender to send again". Any ideas?
Have you gotten and old telephone and plug it in where the fax goes and see (hear) if you have any problems with a good dial tone and phone line? Does your phone line go near any high power a/c units big motors, mite think about a ferrite core for the fax/phone line. hav ATT or other carrier check your line. Also check your own line when ATT does it there check is only to the location not inside the house. Does your sure protector protect your phone line, really good sureg protectors protect Power lines fax lines!!! and in some case network lines
Aug 10, 2009 | HP 1040 Plain Paper Inkjet Fax
Do not have a owners manual to show you how to fax. A sharp ux-114 fax machine.
....and you won't likely find a manual for that old one.
What's so difficult though?
Plug in the power, plug in the phone line to the "line" jack, put in your page(s) face down, dial number , hit "start"
Mar 30, 2009 | Sharp Office Equipment & Supplies
Fax network not working
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
Machine does not answer phone
Some things to check-
I know you said it wasn't unplugged but check the phone line is plugged into the line socket. I don't know how many times I had people who people unknown to them (children, cleaners) have knocked out the line cord and plugged it back in the wrong socket.
Hit the on-hook or hook button and check for dial tone. This will check if the line is still working.
Also the fax will have a mode button. If it has been bumped while moving it could be on manual mode (the machine will not automatically pick up)
Jan 29, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
I need help with a fax machine
Sounds like you may have a noisy phone line, incorrectly set transmission level or no filters installed if using broadband adsl service, also pick up phone is it free of any background noise or crackles? (tel phone company or cable problem if noisy)
In australia there is a service for test fax level across phone line called FOLDS (Fax online diag service) maybe your carrier have one too so you can test?
Oct 09, 2007 | Brother IntelliFAX 560 Plain Paper Fax
HP 6700 Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
