Question about Xerox Office Equipment & Supplies
Hi i ask for help for the error power loss detected in xc7225
Error 303 777
  • Seddik BEN TAIEB
    Seddik BEN TAIEB Jun 16, 2014
    thank you
    i have identified the problem and its in the main LVPS PWB
    Novelist:
  • Xerox Expert
  • 107 Answers
It's an input power loss detected code. It's recommended that you verify your power supply, that you aren't having voltage drops or such at the location.
Repeated 303.777 can be caused by the firmware if power is not an issue.
Call for service if your power is confirmed stable.
Posted on Jun 16, 2014
  • Seddik BEN TAIEB
    thank you i have identified the problem and its in the main LVPS PWB
I'm getting the message system failure with the error code 010030 034c085a on my HP 5500 PS printer...42 in. Does anyone now what it means
Maybe the power in your location has an issue.
System Error: 010030 034c095e
Problem
Description:
This error code appears when the power supply detects a low spike
(e.g. due to a temporary loss of tension). There is nothing wrong
with the Printer.
Corrective Action: Re-boot the Printer and the error code should not appear again.
NOTE If the error code appears again, try connecting the Printer to a
different power socket.
Nov 03, 2014 | Office Equipment & Supplies
Code u2100- u2105
U2100 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Off (4L30-E Transmission) Conditions
Cause Key on and the TCM detected a loss of communication on either Communication Area Network (CAN) Bus line for one second
U2103 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Reset Counter Overrun (4L30-E Transmission)
Cause Key on and then the TCM detected a loss of communication on either CAN Bus line that exceeded 40 time out requirements
U2104 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Reset Counter Overrun (4L30-E Transmission)
U2105 - GM Type Network - Manufacturer Controlled DTC - Manufacturer Controlled Description CAN Bus Error ECM (4L30-E Transmission) Conditions
Cause Key on and the TCM did not receive ECM messages for 1 second
BUT, THERE IS NO FAULT CODES RESULT FOR U2101 AND U2102
or you can ask the 24 hrs live technical support was multi-diag, they will like to help you, good luck
Aug 14, 2013 | 2005 Isuzu Ascender
1998 dodge intrepid loss of power and chk eng light came on
Hi:Just one code there, or your descripotion is about two or mode fault codes; we will need exactly what code number is detected there.
You could find code description here: obd_codes.html
Hope this helps
Mar 05, 2012 | 1998 Dodge Intrepid
Loss of power.chek engine came on. did diag. test and said:heated cat.wec air sys. and acfridge
Hi there:Just one code there, or your descripotion is about two or mode fault codes; we will need exactly what code number is detected there.
Hope this helps.
No Power
Good Day;
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Sep 16, 2008 | Mitsubishi WS-55807 TV
SMART HARD DISK ERROR BACK
hi
SMART Hard Drive detects imminent failure. Your hard disk drive is detecting an imminent failure. To ensure no data loss, backup contents and replace this hard disk
Jyo
Jun 19, 2008 | Computers & Internet
No Power in Mitsubishi VS-55705
Hi John This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Sep 11, 2007 | Televison & Video
Power issue
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 25, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
Jun 09, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-45607 picture goes out intermittently
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
358 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
