Question about Crafts & Hobbies
How can I fix my 3M scotch-Weld AE II Glue gun that drips glue at the tip
  • 77 Answers
I have the same problem. I find pulling the gluestick back slightly between trigger pulls helps
Posted on Jun 10, 2014
  • 3 Answers
SOURCE: I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
Posted on May 21, 2009
Mrteaze
  • 101 Answers
SOURCE: glue stick is stuck in glue gun and can't be
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Posted on Sep 29, 2009
slave2aslave
  • 302 Answers
SOURCE: I can' get the glue stick out of the glue gun
No need for concern. Just leave it there and then the next time you use it push a new one in as needed.
I haven't met a glue gun yet where you can take out the last remnants of glue stick.
If you prefer to remove it try this:
take a paper clip and straighten it (any thin,metal object will work) Heat the glue gun,unplug it,and then heat the end of the paper clip with a lighter/candle.
Insert it into the end that you load from,sticking it into the glue stick. Wait a short time and then pull the paper clip out. The glue stick should come out with it.
I find it easier to leave the glue stick in as I said,but it's your choice.
Posted on Oct 04, 2009
Milleniumboy
  • 106 Answers
SOURCE: master mechanic glue gun 207 stopped working
There is a glue build up inside. Most likely in the feeding mechanism, try to heat it up, the unplug, and use like a paper rolled up to try to remove some of the glue. :)
Posted on Apr 03, 2010
Testimonial: "I ended up removing the tip and heating it with a torch to clean it out."
  • 16 Answers
SOURCE: Cold heat glue gun directions??
Hi There,
Just flip the switch either forward for a brighter light or towards the back for a dimmer light wait 2 mintes and you're ready to go Unless of course its like mine & just want to be a dim flashlight not a glue gun.
Posted on Jan 03, 2011
My 3M scotch-Weld AE II Glue gun drips
There isn't much you can do with that. The trigger may not be fully returning to an open position when you release it; try pulling the trigger slightly (in the opposite direction from what you pull when extruding glue).
I usually keep a paper plate underneath my glue gun because it always drips.
May 14, 2014 | Crafts & Hobbies
How to remove superglue from stretch fabric skirt please
Try an acetone-based nail polish remover. Be aware that you may already have damaged the fabric.
Jun 17, 2013 | 3M Scotch Single Use Super Glue 12 Gram...
Replace the heater element in a polygun
Hi:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 06, 2012 | 3M Polygun AE II Hot Melt Glue Gun
Our Polygun TC was left on for several days. It is difficult to thumb push in the 2" glue slug and is spewing a dark molasses color from the glue tip. How do we clean and clear this problem to...
The dark molasses is the old glue that is in the gun that was "cooked" I don't think the tool is burnt out. I would take a shot at pushing sticks into the gun while it is heated up until the glue that comes out of the tip turns clear. Then the gun should now be "cleaned"
Then unplug it, so that it cools down. After it is cooled , you will be able to remove the old dried up goo from around the tip so that it is completely clean.
WARNING: DO NOT IMMERSE THE GUN IN WATER
The gun is not really designed to be disassembled and cleaned.
The next time you use it, it should be fine.
Hope this helps,
Mark
Dec 16, 2010 | 3M Adhesives POLYGUN TC Glue Gun
What is wood glue sticks
Wood glue sticks are hot glue sticks which are specifically designed for use with wood (such as for glueing together a birdhouse).
Sep 25, 2010 | 3M Polygun AE II Hot Melt Glue Gun
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
I have bleedby so bad I can pull the plunger back
I had some old guns and replaced the air delivery assembly valve. It works great so don't trash your old guns, you may need parts.
Jan 08, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Apr 22, 2009 | 3M Polygun AE II Hot Melt Glue Gun
Crafts & Hobbies Logo
352 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
