Question about Mopar Performance 1997 - 1998 Mitsubishi Montero Sport Brake Pedal Pad Mopar W0133-1637
Mitsubishi montero brake pedal is to hart - Mopar Performance 1997 - 1998 Mitsubishi Montero Sport Brake Pedal Pad Mopar W0133-1637
  • 25 Answers
Sounds like you have a problem with the brake booster.
Posted on May 14, 2014
My brake lights do not work on my 1991 Mitsubishi Montero
My suspicion is brake light switch has gone bad. It's located just above brake pedal below dash. (small plastic switch with a couple of wires - pretty simple fix)
Feb 28, 2011 | 1991 Mitsubishi Montero
My tail lights work just fine but my brake light will not light up when my brakes are being used, is it a fuse issue or wiring? 2003 Mitsubishi Montero Sport LS
Could be the brake light switch that is activated when you push the brake pedal. It is usually located by the brake pedal. When the pedal is up it pushes the switch in, no power to brake light. W HEN YOU PRESS PEDAL, SWITHCH BUTTON COMES OUT SENDING POWER TO BRAKE LIGHTS. CHECK THIS SWITCH FIRST.
Nov 26, 2010 | 2003 Mitsubishi Montero Sport
Replaced the brake switch on a 1998 Mitsubishi Montero Sport and the cruise control won't work
Recheck your brake switch connections. The cruise control as we both kow is shut off when the brake is tapped or depressed. If the wires are connected properly there is the p;ossibility that the brak light switch is out of adjustment. Walk behind the car an see if the brake lights are always on. If they are always on move the plunger further away from the brake pedal actuation arm by adjusting the lock nuts on the plunger stem so that the stem retracts away from the pedal arm.
Thanks for using FixYa.
Kelly
Jun 15, 2010 | 1999 Mitsubishi Montero Sport
Brake lights on 91 montero work only with headlights
Check the ground to the back tail lights, the ground may be poor and when the lights are on and may draw through the running lamps or vise-versa. Inspect the bulb connections and using a multi-meter or inspection light check for 12V DC at the terminals. Have a friend pump the brake pedal to check the brake lights to be certain the switch is ok (the switch is actuated by the brake pedal just under the dash)
I hope this may have assited you,
Tom
Jun 03, 2010 | 1991 Mitsubishi Montero
Montero SUV - squeaky noise when brake pedal is pushed while engine is idling.
this could be 1 of 2 things either you have a vacuum leak and youre hearing a hissing noise or get under the dash with a can of spray lubricant and locate your brake pedal and all its connecting point and spray them down do it until you are satisfied there is no more noise. cheers
Jan 23, 2010 | 2002 Mitsubishi Montero Sport
Brake lights wont work
Check the brake light switch which is located above the foot pedals on a metal bracket.
Apr 07, 2009 | 2000 Mitsubishi Montero Sport
Mitsubishi Pajero, 1999, DiD, Abs and brake light on, no brakes!!
2002 Montero has high pitch sound from dash and brakes are hard
Nov 12, 2008 | 2002 Mitsubishi Montero
Mopar Performance 1997 - 1998 Mitsubishi Montero Sport Brake Pedal Pad Mopar W0133-1637 Logo
Top Mopar Performance GPS Experts
Are you a Mopar Performance GPS Expert? Answer questions, earn points and help others
