Why does the water run through without filling up in the washing machine and it is a Roper Rax6144EQ model?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
The drain valve may be stuck open. If you can't repair it yourself call a local washing machine repair company to replace the drain valve.
Posted on May 14, 2014
SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
Posted on Oct 02, 2008
  • 1462 Answers
SOURCE: Hotpoint Washing Machine Model # VBXR1060T4WB Filling Problem
problem could be the pressure stat which is a switch which detects water level or the pipe leading up to this switch or the air chamber the pipe goes to.
take top off. locate the pressure switch - has a small diameter pipe going to it. remove pipe and fit a similiar one. put on fill and pressurise this pipe by mouth and water fill should stop. if it doesn't, then switch is faulty.
if this is ok, examine carefully the small diameter pipe for splits and blockage. also check the air chamber for build up of gunge
Posted on Nov 16, 2008
Dissolu
  • 221 Answers
SOURCE: roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
Posted on Jul 25, 2009
  • 1218 Answers
SOURCE: My roper washing machine wont stop filling, water
If when you shut off or unplug the machine, the water stops response #1 is correct.
If shutting it off or unplgging it, doesn't work and you have to shut the water off at the shut off valves, the dual water valve is bad.
Posted on Nov 03, 2009
  • 24 Answers
SOURCE: brand new roper washing machine model # RTW4440VQ2...
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
Posted on May 26, 2010
Rinse cycle only fills halfway
alot of newer machines do that. water saving feature
Dec 04, 2015 | Roper Washing Machines
Runs without water
Water level is sensed by pressure against a diaphragm switch. This switch is always mounted above water level, and is connected to the bottom of the outer bowl by a plastic tube, usually 3mm ID. Either the tube has become blocked or the connection point. Also the diaphragm switch could be faulty.
Apr 01, 2014 | Roper Washing Machines
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
May 20, 2010 | Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Roper washer fills with water continuously
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares'
Feb 23, 2009 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Wont fill up with water it drains out before its full
If you hear the motor running when it is draining then you have a bad timer. If it just drains out and the motor is not running then you have a siphon problem which is caused if the drain hose is too low. Let me know what you find.
Dec 03, 2008 | Roper RAS8445KQ Top Load Washer
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
