Question about Honda Electrical Supplies
What would cause a Honda Generator not to stay idled up?
3000- won't stay idled up
    Sniper:
  • 60 Answers
There's 2 possible causes . I believe there's a service bulletin from American Honda to replace the small electric motor on top of the carburetor , if still under warranty you good if not have your local dealer contact tech line for a good will warranty . 2nd cause is the inverter behind the front panel . The inverter controls spark , idle and all of the electronic and electric components on your generator . Hope this helps
Posted on May 18, 2014
3 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Posted on Mar 01, 2009
SOURCE: honda generator (eb5000) will not idle steadily
use premium non-ethanol fuel(shell,BPS etc).Many stations to the west & north (,Hustisford & many other town's PREMIUM are non-ethanol) and add some sea foam to it. that ethanol is junk. If not used in 30 days toss it. nothin' but trouble.
Posted on Jun 25, 2012
Have continually to increase speed to maintain voltage
Check the idle-stop screw. They tend to back out, causing the generator to slow down and not maintain regulation
Oct 17, 2014 | Honda Ex5500 Generator Solenoid Stay...
Why is spark plug breaking down on new honda generator 3000?
If the plug isn't fouled and looks all right, it could be the resistor cap on the plug wire. It could also be a warning from the CDI that it is giving up the ghost.
Jul 05, 2014 | Honda 3000 Watt Portable Generator
I have a honda 3000 generator that wont stay idled up?
They are not supposed to. Only Idle up when they need to generate more . Mine stays at Idle and it happily runs my Refrigerator
May 14, 2014 | Honda 3000 Watt Portable Generator
My 3000 watt honda generator doesn't seem to put out the proper power
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf
I would check spark arrester and clean it and the muffler first.lt could be the inverter unit. If you have a meter determine the output voltage, and freq. You would need a scope to look at waveform the repair should be lest to a repair center. suggest you call Honda for more guidance.
You could spend a lot of money on maybe parts./
Nov 30, 2017 | Honda 3000 Watt Portable Generator
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
Idle problem
turn the idle screw down on the carburater
Feb 17, 2009 | 1988 Honda Accord 4 Door
Electrical Supplies Logo
146 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
