Question about Toaster Ovens
Hualilai fz31 9e switch
Where to find a replacement of this switch
How can I get the Timer/Power switch for Hamilton Beach 31199xr toaster oven.
EBay, partselect.com, hamiltonbeach.com or your local appliance parts store.
Mar 08, 2015 | Hamilton Beach 31199xr Countertop...
Oven gives air flow fault message . I did check all the safties ,motors everythings looks fine any suggestions
Check your combustion switch to see if it has a screw to adjust the amount of vacuum needed to prove the air flow. Adjust it down. Bypass the switch to see if the problem continues, if it does it is in the PCB or the ignitor control. If the problem goes away then replace the combustion relay switch (proves air flow).
May 13, 2010 | Baxter OV300G Stainless Steel 27817 Watts...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
My black and decker toaster oven is less than a year old and it has a burned out smell coming from it. I feel it might be a fire hazard and I am not comfortable using it anymore for fear of fire. What can...
Your problem is very likely the timer switch. They are very poorly made and they have a high failure rate. B&D should have a recall on these switches. It's likely a DKJ/1-60 timer switch. They make a very poor electrical contact which causes the switch and possibly the wall plug to overheat. Mine melted the wire insulation at the switch and failed. These switches are impossible to find fortunately because they are all subject to the same failure. There are a couple timer switches made for Delonghi ovens that will work in the B&D and other ovens that use the DKJ/1-60 timer switch. One is part # 5218104600 which works the same as the B&D switch but it only has about a 13 minute toast timer. Turn it counterCW to turn the oven on. There is another switch with a 120 minute timer which is part # 5218101800 but may be harder to find. The 13 min timer switch can be purchased for $10.98 at Gourmet Depot website. Another solution is to replace the bad switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts AC. You will no longer have a timer and you will need to turn the oven on and off manually but at least you will be able to use the oven and the switches are under $10 and much safer than timer switches.
Mar 06, 2010 | Black & Decker CTO649 Toaster Oven with...
BLACK & Decker Countertop owen Model: CTO 649 does not work
Try smallappliance.com for your parts or just google search "small appliance parts" and you'll see a few places that have B&D parts.
Sep 19, 2009 | Black & Decker CTO649 Toaster Oven with...
Toster Timer Switch Broke
I had the same problem with the same exact switch DKJ/1-60. This part cannot be found anywhere but the factory and you'll have to buy 5,000 if you want one. There is another switch made for Delonghi that will work but it only has timer for toast. No 60 min. timer. The part # is 5218104600. This switch works the same way as the original but you will only have about a 13 minute timer. There is another one that has a 120 min. timer. The part # is 5218101800 for Delonghi. These switches look the same as the DKJ/1-60 but you may need to use parts from your old switch to mount these switches. Another solution to the problem is to replace the bad switch with a single pole single throw toggle switch that will handle 20 amp's on 120 volts AC. You will no longer have a timer and you will have to turn the oven on and off manually but at least you will be able to use the appliance. The above switch can be purchased at Gourmet Depot website for $10.98.
Jan 28, 2009 | Black & Decker CTO649 Toaster Oven with...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Toaster Ovens Logo
209 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
