Question about Steele GG-1000E - 10,000 Watt Gasoline Generator
How to adjust valves on steele gg-1000e generator
    Habit-Forming:
  • 74 Answers
Just search on You tube as Pakistan free energy Magnet motor. you will forget generators. See professor Yel free energy magent motor in delft university on Youtube.....
Posted on Apr 06, 2016
Have a steele 6000 will start but then dies
just search on You tube as Pakistan free energy Magnet motor. you will forget generators. See professor Yel free energy magent motor in delft university on Youtube.
Oct 17, 2015 | Steele Products 6000 Watt Portable...
Why is my generator not starting
Check for fire to the plug. If so, the give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 06, 2014 | Steele Products 6000 Watt Portable...
Runs at a galloup but wont continue to run
check spark plugs and engine carbon level. change filters. otherwise search on youtube about delft university free energy magnet motor.
Apr 15, 2014 | Steele Products 3250 Watt Portable...
Steele 9000 watt generator won't start
Hi Derrick
I assume you can turn over the engine, and the engine has run previously?
Check for spark, -take off the plug lead and connect an old spark plug to the ignition lead open the gap up to about 5/16 inch . Tie the thread of the spark plug to the engine to hold it and earth it with a bit of soft wire. Wind over the engine you should get a nice fat blue spark. If you get a nice spark do you can eliminate ignition issues. This just leaves fuel. You can then focus on this.
Jacko
Apr 13, 2014 | Steele Products 9000 Watt Portable...
The middle burner puts out gas, but the two outside burners do not.
Not enough information. If we assume the other two control valves are turned on, are the orifices clogged, are the valves leaking, are there safety valves attached the the natural gas line to detect leaks?
look down inside the valve stem to see if there is a tiny screw. this is an adjustment for the valve to allow more or less gas flow. if the valve was damaged or tampered with this could generate better flow. if the appliance went a long time without being used the valves could be clogged. remove the orifices and blow out the orifice and the valve with the orifice removed.
Mar 09, 2014 | Char-Broil Commercial Stainless Steel...
Please tell me How to change my oil in my ust gg 2300 generator
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing...
Aug 17, 2011 | UST GG2300 Portable Gas Powered Generator
Where can I get parts for a GG 5500 series gas generator? Thanks Van Holton
here is the url for the parts site that porter-cable uses for consumer parts ordering
http://servicenet.deltaportercable.com/
Aug 08, 2011 | Porter Cable Portable Generator BSV750
My generator is poping or firing back through the carb. What is the problem.
Generally this is caused by leaking intake valve. The valves could be out of adjustment, weak or broken valve spring or bent valve. If the generator was not used for a while, rust could have formed on the seat. Easy to check compression and compare to factory specs. Or loosen valve adjustment a bit and run engine with upper cylinder lube in fuel or squirt directly into carb. If it does not improve may be time for valve grind. Not too difficult. Good luck on your repair
Jul 09, 2010 | Coleman Powermate Premium Plus 6250W...
Steele GG-1000E - 10,000 Watt Gasoline Generator Logo
27 people viewed this question
Top Steele Electrical Supplies Experts
Lawrence Oravetz
kamal dev  jhalli
kamal dev jhalli
Jacko
Level 1 Expert
Are you a Steele Electrical Supply Expert? Answer questions, earn points and help others
