Question about John Deere 22HP VTwin Hydrostatic 42" Riding Mower
How to fix Stuck in reverse Clutch is Fine.?
It is Stuck in reverse, have to Pull An Jump start it in reverse to move it. No forward gears ?
  • ric hane
    ric hane May 14, 2014
    Its not hydrostatic it is a clutch drive JohnDeere 4600 Tractor
  • 25 Answers
Have you tried checking the linkage to the hydrostat/transmission? Are you getting full movement of the lever? If not, it might have just come loose and shifted so you only have reverse. If you have full movement of the lever and the hydrostat has the proper amount of fluid it could be fried. It's hard to tell without diagnosing the linkage. I'd suggest blocking the rear wheels off the ground so you don't run over yourself before you go messing with the linkage.
Posted on May 14, 2014
The tines are not moving forward on my Rotavator. The engine is Tecumsah Vantage 50. The tines move backwards and the engine seems fine. The rotavator will not move forward
I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
More information needed, perhaps...
Jul 24, 2016 | Garden
My Audi 2003 A6 is stuck in neutral starts but don't move.
Is it a manual transmission or an automatic? If it's a manual (clutch pedal), then you've got a problem for the shop. If an automatic, it should shift into a forward gear or reverse whenever you depress the brake.
Jun 04, 2016 | 2003 Audi A6
Vs auto have forward gears even in reverse any ideas please
A4LD stuck in forward, even while in neutral and reverse. - Ford ...
https://www.explorerforum.com/forums/showthread.php?t=216567
May 27, 2008 - 19 posts - ‎5 authors
I did find a thread that referred to an "always in a forward gear" A4LD problem, ... Eventhough band adjustment should not have anything to do with the .... in the transmission and then it auto shifts through the gears normally.
700r4 forward in all gears, even neutral, no reverse - Third ...
www.thirdgen.org/forums/.../631383-700r4-forward-all-gears.html
Oct 21, 2011 - 700r4 forward in all gears, even neutral, no reverse ... It has no reversebut when I put it in reverse it tries to pull the motor down like the rearend ...
my car is not moving forward or backwards even with gea
Dec 27, 2015 | Cars & Trucks
Why does my 2007 1100 V-star die when I put it in gear?
Hi Don does the bike jump forward as of the clutch wasn't working? If so the clutch is stuck. To fix put thd bike in high gear and hold in the clutch push the bike back and forward with the help of a friend until it frees up. If this is not the problem check the side stand switch it might be faulty. If you have a doubt about the switch join the two wires together temporary to test. Regards Jim...
May 10, 2015 | 2007 Yamaha V Star 1100 Classic
06 kia spectra how do your adjust the shift cables on a manual trans all forward gears are fine problem is with reverse no problem untie we changed the clutch
The clutch is not clearing properly ,so wait a while for it to level itself off ,to get reverse in the meantime you stop engine ,put in reverse then start engine ,if after a while it still doesnt work and tries to jump out of gear you will have to strip the gearbox and change the dog gear
Dec 11, 2014 | 2006 Kia Spectra
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
Put xrays transparency (once) The shredder is stuck, gears don't move
First - did you reverse it? If that didn't work, unplug the shreader , trun the cutter head over and use a pair of tweezers to pull out the stuck pieces. You may have to turn -forward & reverse - a fe times.
Apr 16, 2014 | Fellowes DM12C Shredder
Gsx750 clutch cable
See if you can push the bike with it in gear and the clutch lever pulled in. If the clutch is stuck, push start the bike, jump on, get to about 10 mph, pull in the clutch lever and hit the rear brake hard. This will usually break a stuck clutch loose.
Mar 21, 2014 | 1988 Suzuki GSX 750 ES
Kia Rio 2005 manual, the gear will get stuck and car shakes and stalls on its own when I come to a stop, foot on clutch and brake, in reverse and first gear.
what would happen if you put it in first gear,put your foot on the clutch then try to start the car....of course pick a place where safe!!!...if it rolls forward while cranking ,the clutch plate is touching the flywheel (in other words the clutch all the way down while in gear while cranking,should NOT touch the flywheel(transmission part that makes the car move) so if it moves then it shows the transmission reacts to the clutch touching the other jiggamathig. Possibly clutch system needs bleeding (air in the hydraulic system). I'm sure your car has this thing called a "clutch slave cylinder". Now,this is one thing I would check first.
Dec 21, 2013 | 2005 Kia Rio
Automatic transmission of toyota sera i couldn't move reverse it gets stuck rest is fine
It may be due to:
- Maladjustment of the gear lever cable or selector assembly.
- Valve body assembly.
- Planetary gear unit.
- Reverse clutch.
Nov 27, 2013 | 1992 Toyota Sera
John Deere 22HP VTwin Hydrostatic 42" Riding Mower Logo
192 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
