Replacing lid switch on maytag mtw5830two washing machine
Get at lid switch on the maytag mtw5830two
dazmaraz
  • 67 Answers
SOURCE: Washing machine lid switch
not sure what machine tou on about,but no switches should be bypassed
Posted on Oct 16, 2007
SOURCE: replacing lid switch on Kenmore 80 series washing machine
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
AlmostBob
  • 550 Answers
SOURCE: Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Posted on Aug 29, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
SOURCE: replacing roper washing machine lid switch
I have a new lid switch for the make of waher,and I need a digram on how to get into the washer
to replace the awitch.
Posted on Jan 22, 2009
Maytag Atlantis washing machine does not rinse, spin or drain
You need to make sure that the switch on the door/lid is making a connection. If the lid is not closing completely, clear whatever is not letting it close. However, if it's closing but still not working you may need to replace the switch. I have had them go bad an not make a connection when the lid closes.
Mar 31, 2014 | Maytag Washing Machines
Maytag washing machine washing but not rinsing, spinning or draining
You need to make sure that the switch on the door/lid is making a connection. If the lid is not closing completely, clear whatever is not letting it close. However, if it's closing but still not working you may need to replace the switch. I have had them go bad and not make a connection when the lid closes.
Maytag mtw5830two
check for an intermittent lid switch if you don't see the small hole under the lid where it closes the the plug in is under the control counsel unplug, jumper unit should start to agitate after it fills look at the colors on the wire plug do not stick jumper wire in green hole you if it has one this is ground you will trip the breaker
Jan 23, 2014 | Washing Machines
The washer is not spinning.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.Replace the "lid switch" with this part.
Jan 02, 2011 | Maytag Ensignia MAV2757AWW Top Load Washer
Washing machine fills with water but will not go on to the wash cycle . The machine just fills with water and stops. Have to bail out the water by hand.
Your lid switch needs to be reset or replaced. Open the control console to access the lid switch. Check the fuse for continuity. Check the alignment of the lid switch for contact with the micro switch.
If these cannot be reset they must be replaced.
Oct 08, 2009 | Maytag Washing Machines
Maytag A612 washer washes, but will not drain
Replace the lid switch. Open the control console and find the lid switch in the center of the console.
Jun 30, 2009 | Maytag Washing Machines
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lid swith
Open the top of the unit by placing a putty knife beween the top and the front panel about two inches in. There is a spring lock that you need to push in, then lift the top. Once you lift the top, you will see the lid switch. Remove and replace. Let me know if you need further help. Jim
Nov 28, 2007 | Maytag Performa PAV2200
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
