Question about Garden
How to fix John Deere 4600 stuck in reverse can't shift to forward gears?
The clutch is operating proper, Boss may have jammed the shifter while on the go .
    Champion:
  • 279 Answers
The transmission/rear end will have to be taken apart. Most likely the keyway has broken and the gear is stuck in place.
Posted on Jun 03, 2014
3 Suggested Answers
  • 483 Answers
SOURCE: John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Posted on Mar 23, 2013
  • 1169 Answers
SOURCE: I have a John Deere SRX95 mower. It does not
Check your transmission's shifter detent ball and spring. They probably have rusted.
You look at the IPL here >
SRX 95 Parts manual
Posted on Oct 22, 2013
I have a 1987 Nissan Hard-body V6 4-Wheel drive with a manual transmission. My gear shifter will only go into 1st, 3rd & 5th gears. It will not go into 2nd, 4th or Reverse. It acts like it is
Sound like the syncros have worn out. Have you tried rowing down the gears starting in 5th, 4th etc at a stop with th clutch pushed in? How many miles on the current clutch?
Oct 21, 2014 | 1986-1997 Nissan Pickup Side View Mirror
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
Trouble shoot a John Deere lx 188 clutch?
Sounds like new belt is jammed or something is out of place. Turn by hand and find out where the problem is. You can tell where the belt is stuck or jammed. Pull the key before you mess with stuff underneath the unit. I installed my belt the wrong way on my unit and ruined a new belt and it would not shift.. The shifter rod could have been dislocated when you installed the belt also.
Jul 27, 2014 | John Deere Garden
How to fix Stuck in reverse Clutch is Fine.?
Have you tried checking the linkage to the hydrostat/transmission? Are you getting full movement of the lever? If not, it might have just come loose and shifted so you only have reverse. If you have full movement of the lever and the hydrostat has the proper amount of fluid it could be fried. It's hard to tell without diagnosing the linkage. I'd suggest blocking the rear wheels off the ground so you don't run over yourself before you go messing with the linkage.
May 14, 2014 | John Deere 22HP VTwin Hydrostatic 42"...
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My jd 2355 is stuck in reverse, can't get it out of reverse to get it started> any ideas, please? it has a 6ft single stage blower on the back, also.
You can try pulling it ahead a little to take the load off of the shift rods.Also,check your clutch fluid and if you have run out than it needs to be filled up and bled out.If none of the above the the shift cover needs to come off to check for jammed gear or broken split pins.
Dec 18, 2009 | John Deere Garden
Won't go forward, only in reverse
You need a forward/reverse switch, most likely.
http://www.rungreen.com/john_deere_peg_perego.html
You can replace the whole shifter for $28, but the switch may work fine.
Jul 11, 2009 | Peg Perego John Deere Gator HPX
I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
Apr 16, 2009 | Peg Perego John Deere Turf Tractor
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
