Question about Samsung SCX 4521F All-In-One Laser Printer
Date and time change
Fix date and time error
  • Samsung Master
  • 2,013 Answers
Fix errors certificates problems for free
it it your time and date need to be changed to the right time and date
May 22, 2014 | Dell Dimension Computers & Internet
Error code 1202
The problem may be caused by wrong date/time or zone settings. change your settings with the correct timezone ,date and time then try to reboot . Hope this will fix your problem.
May 14, 2013 | Apple iPhone 4S
What is the solution to error code 0x80072f8f which occured during window activation?
Try this one.
  1. Click the Start Collapse this image Expand this imagevistastartbutton.jpg, type timedate.cpl in the Start Search box, and then click Timedate.cpl on the programs list.
  2. On the Date and Time tab, make sure that the computer's date and time are correct. If the settings are incorrect, click Change date and time.
    Collapse this image Expand this imagesecurityshield.jpgIf you are prompted for an administrator password or confirmation, type the password, or provide confirmation.
  3. In the Date and Time dialog box, use the following procedures:
    • To change the date
      Under Date, click the left or right arrows to find the current month in the calendar, and then click the current date.
    • To change the time
      Under Time, double-click the hour, minutes, or seconds that you want to change, and then click the arrows to increase or decrease the value.
  4. When you finish changing the date and time settings, click OK.
  5. Try to install updates again.
May 20, 2011 | Microsoft Windows Vista Ultimate Edition
Error 0271 : check date and time settings fan error how to fix this 2 error on IBM think pad 2647-2 TU, it display when turn on the power. thanks alot
Easy way is to run the setup utility and clear the date and time - else go into BIOS and change the date and time to the correct ones. If it keeps reverting then you need to put a new battery in.
Sep 17, 2010 | Computers & Internet
My kids Ds's have a msg that comes up as soon as it is turned on. It says "system date error! Please check nds system date. They Both started diong this at the same time. How do we fix it?
Remove any game cards, then enter the system configuration. Browse to the Date section, and change it appropriately. This could have happened because of some sort of Daylight Savings Time bug.
Jul 27, 2010 | Computers & Internet
System date error! please check NDS system date
It's a bug issue in the firmware of the R4 cards. Won't work after 14 april 2010 unless you update the firmware of the R4 card.
For the time being you can set back the date before 14 april 2010 and it wil work directly.
gr
Apr 19, 2010 | Nintendo DS Lite Console
Hot to fix time and date error
When you change it on Windows, did it re-occur after restart?
Try changing the Date from BIOS settings.
If it still re-occurs, change the CMOS battery, set the time and check it again.
post what happens after.
Feb 15, 2010 | Intel DG31PR Motherboard
Battry
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | ASI CL51-15 Notebook
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
Thinkpad 380ed
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Sep 19, 2007 | IBM ThinkPad 380ED
Samsung SCX 4521F All-In-One Laser Printer Logo
69 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
