Question about Dryers
Dryer has a squeaking noise. does it need to be
Dryer has a squeaking noise. does it need to be lubricated?
  • 10,865 Answers
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Posted on Jun 23, 2009
  • 520 Answers
Change the belt and check all of the bearings for play. If any have too much slack replace them.
4 Suggested Answers
  • 100 Answers
SOURCE: my series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Posted on Aug 10, 2009
SOURCE: Bosch Dryer squeaking noise
We also have a bad squeak in our Bosch dryer that drives you crazy. The Bosch serviceman when he came to look at the problem said his own machine did the same and he gave up trying to fix it, cheaper to put up with the noise. I purchased Bosch because I thought it was one of the best, I will not be buying Bosch again!
Posted on Apr 18, 2010
  • 2006 Answers
SOURCE: the dryer has developed a hi pitch squeak. Does
Usually the hi pitched squeal is either the belt slipping or the bearing. It the drum hesitates at start, then look at the belt as the culprit. But that sound unsually stops after the drum starts retating.
If it grind all the time it is probably the bearing http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dryer-Parts/Model-FSG748GFS0/1428/0151200/Y2704973/00002?blt=06&prst=&shdMod= ITEM 12.
If it is loud then I would replace the bearing and lubricate it well with lithium grease.
It isn't that hard to do but does require you to remove the front and top of the dryer, so I hope you are comfortable with that type of work.
Posted on Jun 19, 2011
Dryer makes a squeaking noise when turned on. After dryer heats up noise gets quieter then stops
Take the dryer cover off somehow. Chances are your belt may be wearing out, or a belt tension pulley may need lubricating. There are also rollers I believe the "drum" travels on. You'll know alot more with the cover off. Good Luck!
Apr 10, 2015 | Roper Dryers
Dryer is making noises and from what I read I need to lubricate the rollers?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 16, 2011 | Amana NDG5805AW Gas Dryer
Have a Kenmore 70 series. It"s squeaking while running. Lubricant? Bearing?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 30, 2010 | Kenmore Dryers
Hotpoint dryer drum squeaks during any setting Checked belt and it is not worn and is still tight and in place. Lubricating belt does not help.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 13, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
My series 80 dryer squeaks
Aug 10, 2009 | Dryers
Squeak when running the dryer
It's the roller axles and/or the motor shaft. Remove the front of the dryer and lubricate same.
May 27, 2009 | Hotpoint NBXR463EBWW Electric Dryer
How to stop squeaking noise on dryer
The roller bushings/bearings and the motor need lubricating.
If you want help with how to do this, let me know.
Apr 30, 2009 | Dryers
Maytage dryer squeak
do NOT use WD40 in a dryer. WD-40 has considerable flammability ingredients. the rotor is most likely the blower . check the wheel and the motor. could be loose or have something in it... if you want to lubricant.. use a high temp lubricant made for dryers..
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I have not seen any service manuals online. The squeak will possibly be a rubber bush used to silence the machine. If you get it stripped down you should be able to locate the squeak by carefully applying pressure in different areas and the squeak should go... then hopefully you will have found the culprit.
Mar 15, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
239 people viewed this question
Top Dryers Experts
Marvin
Marvin
