Question about Exhaust for Chevrolet Camaro Convertible
How to stop an edlebrock carb spitting through the carb?
    New Friend:
  • 15 Answers
Carb needs a rebuild
Posted on May 15, 2014
I have a ford cvh 1600 what backfire through carborator only when it is hot and then lose its power
Ford Escort carb backfire Questions & Answers - Fixya
www.fixya.com > Forum > Tags > carb backfire > Cars & Trucks > Ford
Ford Escort cars & trucks carb backfire questions and answers. ... Backfire throughcarborator and engine stopped upon returning from store. ... Turbo conversion from 1995 on a CVH engine - engine cuts out ... I have a xr3 ford escort 1600 with a weber carb,itbackfires and spits fuel up Clean the Carburator completely.
I have a xr3 ford escort 1600 with a weber carb,it backfires ...
www.fixya.com/cars/t10838117-xr3_ford_escort_1600_weber_carb
Nov 17, 2011 - I have a xr3 ford escort 1600 with a weber carb,it backfires and spits fuel up ... Turbo conversion from 1995 on a CVH engine - engine cuts out.
All comments on Ford Escort CVH Straight-through exhaust ...
https://www.youtube.com/all_comments?v=1yA5blCpTLM
Jan 05, 2016 | Ford Cars & Trucks
Hi have a 75 eldorado. The car ran and drove fine until put an edlebrock carburetor. The car still runs good and drives but it will not shift into second. I have suction on the trans vacuum line.
Hi Jonathan, When you installed the Edelbrock carb did you readjust the kick down cable for transmission? And does it shift hard in other up shifts?
I’m happy to assist further over the phone at https://www.6ya.com/expert/randall_d932ef6e01588b0f
Aug 10, 2015 | 1975 Cadillac Eldorado
Just replace the carburetor in a 1975 chrysler newport which has 400 w/ 4bbl carbur. with an edlebrock. now my problem is the car will kickdown too soon or will have to shift manuely to get it to kickdown....
it could be your nuetral safety switch on trans.But if you just replaced carb I would start by making small adjustments to cable that goes from carb linkage to trans
Jun 10, 2011 | Chrysler Newport Cars & Trucks
I have a stock chevy 350 of which i just installed a edlebrock intake and edlebrock 600 w/electric choke runs good but has delay on initial acceleration after it catches up takes off really well idles well...
I am not sure what type of Carb you have but I will assume it is a Holley ( Most Popular ) The accelerator pump arm on the carb probably needs to be adjusted.It is adjuster by bendinding the end of the arm. Also the accerlerator portion of the carb could be a bad one.The other possibility is the metering jets are too small to feed your demands of your engine on hard aceleration.Or your air/fuel mixture is incorrectly adjusted and it is runnig to lean or to rich.
Apr 26, 2011 | Chevrolet 1500 Cars & Trucks
The car stays on a short time even when i turned it off.
Carb should be rebuilt or replaced. Then check linkage for binding
Oct 14, 2010 | 1985 Chevrolet Monte Carlo
I have a pontiac 389 with an edelbrok performer manifold and 750 edelbrok carb. wondering if this is a good set up and how can I fine tune it. it boggs down when I go wide open on the throttle, it feels...
I would recommend replacing the carb with a double pump holley performer series, I have had bad luck with the edelbrock performance, and their is always a lag when the secondaries open due to no accelerator pump on the secondaries.
Feb 16, 2010 | 1978 Pontiac Bonneville
1984 corvette fuel solenoid
unfortunatly you are going to have to run new power and a new pump. a fuel injection pump runs 30 psi minimum some of them quite a lot higher than that. a carb cannot have more than 7psi without bypassing the float in it and overflowing the carb with fuel. when going to a carb you will have to get a low pressure fuel pump and completely rerun the fuel system
Apr 28, 2009 | 2003 Chevrolet Silverado Ss
Carb choke
yes ground and hot
youur hot wire needs to hook into ignition circuit so it is hot with key on
Sep 05, 2008 | 1966 Ford Mustang
Exhaust for Chevrolet Camaro Convertible Logo
22 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
