Question about Dell 3200MP Multimedia Projector
Dell 3200mp projecto shows diagnal color lines
2 Suggested Answers
early1234
  • 871 Answers
SOURCE: Dell 3200mp lamp
are both of the lamps the same? have you installed it correctly in the socket. you might need to do a cold start for your projector. unlpugg it and try to wait for 5 minutes before plugging it again and turning it on. one your projector detected that a new lamp is intalled, it should work fine now. but if its still not working, you might want to try and replace the new lamp again. sometimes this happens.
hope this helps.
Posted on Feb 20, 2008
Dell 3200MP DLP Projector: displays OK, but with vibrations soon as power button is pressed ON. found cause; rotating see thru thin plastic disk has a quarter of the disk broken off, thereby causing...
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Jul 04, 2011 | Dell 3200MP Multimedia Projector
Dell 3200mp lamp
hope this helps.
Feb 20, 2008 | Dell 3200MP Multimedia Projector
I need a new colour roller for the projector which is now out of manufacture and warranty
Go to ebay.com This projector is in good physical condition and powers on, but it only white. Lamp/bulb is NOT included.
Manufacturer: Dell
Model: 3200MP, 7W625
Cosmetics: Good
Test Results: Tested to power on only. Sold AS-IS, with NO warranty.
Accessories: Power Cable, Carrying Case
Nov 16, 2010 | Dell 3200MP Multimedia Projector
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Dell 3200mp
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @ussmillerco@yahoo.com and let me know. Good luck thx sean
Nov 21, 2008 | Dell 3200MP Multimedia Projector
Dell 3200MP DLP Projector Fan Problem
i would take it a part and look, I would be it is a 60mm or 80mm case fan....
newegg, xoxide, performance-pcs or any other PC shop will have 60mm and 80mm case fans.
just chop off the connector from the old case fan and crimp, solder (sp?) or twist with tape the connector back on......
Aug 25, 2008 | Dell 3200MP Multimedia Projector
Dell 3200mp
Hi Lagnitta
Take out the lamp and check for any irregularities like discolouration and marks.
This is unfortunately dammage to the lamp and the lamp will need replacement.
Thanks for using Fixya.
Apr 27, 2008 | Dell 3200MP Multimedia Projector
No signal on screen of Dell Projector 3200MP
start your laptop first then your projctor-if the problem still excit-press-control+f4 or control+f6 or control+f7
Mar 05, 2008 | Dell 3200MP Multimedia Projector
Green tint
Adjust the color temp, it worked for me. I had to turn mine off but now the color is perfect.
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Dell 2300mp projector
Did you ever get a solution to this? I am having the same problem with my 3200MP The machin will come up but only show a dim white box on the screen. I've purchased another bulb and that was not the problem. Angie Black ablack@4are.com
Feb 27, 2007 | Dell 3200MP Multimedia Projector
Dell 3200MP Multimedia Projector Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
