Question about Amana Kitchen Ranges
Amana artsc8651 Why is my control panel flashing between timer and clock and beeping every time it flashes. Last night my Amana Electric Slide-In Range started beeping. I was in the living room and had not used the range for hours, and the timer had not been used for a couple of weeks. I tried to shut off the timer, nothing happened. I tried to reset the clock, which I did successfully, but just a couple of minutes later it started flashing and beeping again. I just went and flipped the breaker to shut it all off. I am terrified of fire and did not want to take a chance of the range starting itself or having it go into self-cleaning mode, which I have never used. The range is a little over 11 years old. What do I do now? Thank you.
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Posted on Oct 23, 2008
SOURCE: F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Posted on Dec 23, 2008
aborcass
  • 2651 Answers
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Posted on Mar 18, 2009
SOURCE: F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Posted on Dec 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
We have an Amana AMC6138AAS microwave/convection oven. I was cooking popcorn last night and opened the door before the timer stopped. When I opened the door the inside light and the control panel went...
Did you have a power failure? Could be an overheat situation. Try unplugging the unit, wait 30 seconds and plug it in again. This resets the unit as long as there isn't a breaker or fuse blown. If it is a power issue, the display should start flashing. Did you get any error codes?
Dec 20, 2017 | Amana Microwave Ovens
Amana ARGS7650SS Gas oven takes a long time to heat up, and then, in the middle of baking, the digital control panel goes blank and the oven goes off. Eventually, the panel will begin flashing and, with...
This is Amana's fault and is common on several oven models and types.
Your timer and clock control board has some loose solder joints and they can be re-attached by any competent electrical repair shop with soldering skills. TV shops can often be convinced to do this for you for a nominal fee.
Nov 07, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana slide in range F1 error
f 1 code is the electronis range control failure.. ( clock ) it's not a hard job . turn off power!!! open the control panel - screws under edge/ the clock is held with 4 small screws . remove the wires one at a time ( don't mess them up or wala the new clock is up in smoke .. ) install wires one at a time all terminal are marked . reinstall / plug in / reset time and oven will work .. mm hope this helped.
Dec 04, 2009 | Washing Machines
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
Our Amana AGDS902 Gas Kitchen Range is beeping and flashing an F7 error code. We have found solutions for other Amana ranges online, but none of them seem to be for our exact range type. We can stop the...
AMANA – Range/Stove/Oven Fault Codes
Glass link Electronic Range Control (ERC)
F7=Shorted touch panel Verify glass to adapter board connection good, if so, replace glass panel.
Dec 02, 2017 | Amana AGDS902 Gas Kitchen Range
Errorcode F4 Amana ART6610E
Hello Welcome
F4 means on an Amana Range or Oven:
Condition is a open or shorted oven temperature sensor
Check and or Replace oven temperature sensor
Please remember to leave a solved rating before you leave
Huum at your service
Dec 21, 2008 | Ovens
Amana acs7270ax stove beeping and flashing panel
The F1 error code indicates a control board failure. You need to replace the electronic control board. Good Luck Please rate
Dec 18, 2008 | GE Spectra JBP78 Electric Kitchen Range
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Kitchen Ranges Logo
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
