Question about Nikon S8100 Digital Camera
The buttons on the back of the wheel aren't functioning
The wheel turns fine, but the actual buttons (flash, macro, timer)are not responding. What do I do?
2 Suggested Answers
Rider On Way
  • 1679 Answers
SOURCE: I have nikon L10. The flash does not work. But it works if I click using self timer
Try this link below and check if this is the case.
Click here -> Nikon L10 Troubleshooting
If that does not help you, try the steps below
Click here - > Alternate Method
Regards,
Suhail
Posted on May 15, 2012
Unable to set up remote URC 22935
MENU • Set Up • Searching For Yor Code • Blinking Back the Code:
Redefining a Key • Punch Through • Volume Default • Clearing Out
Key mover • Favorite Channel Scan • Macro-Sequence
How to Program your One For All remote
(Models URC-2005, URC-2099, URC-4005, URC-4050, URC-6050)
Set Up
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
PRESS and HOLD the MAGIC button until the red LED flashes twice, then RELEASE.
ENTER the 3 digit code for your brand.
You should receive 2 quick flashes after entering your code.
PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
menu
If you have tried all of the set-up codes for your brand of eqipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following proceedure to search for your code.
ENTER 9-9-1 (two blinks on the remote)
ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
When your device turns OFF, PRESS the MAGIC button and RELEASE it to lock in the code for your device.
menu
PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
PRESS 9 - 9 - 0.
PRESS 1, carefully COUNT the number of blinks. (1st digit)
PRESS 2, carefully COUNT the number of blinks. (2nd digit)
PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
menu
Redefining a Key
PRESS 9 - 9 - 2.
PRESS the DEVICE,(TV,VCR,CABLE,etc.),key you want moved
PRESS the DEVICE key you want to replace.
Example: If you want the Aux key to be a TV key:
"MAGIC" (2 blinks) 9 - 9 - 2, TV (you want to move TV)
Then AUX (you want to replace AUX).
menu
Punch Through
This sets Volume to work for one device in all modes.
For example, the TV volume will work in the cable and VCR modes.
PRESS 9 - 9 - 3.
PRESS the device key you would like the volume to come from.
You will get two blinks on the remote.
NOTE: This only sets volume in the TV,VCR,CABLE, or SAT mode.
If you want to set the volume for a device to work just one or two other devices- refer to the instructions under "KEYMOVER-From one button to another"
menu
Volume Default
Use this to get the original volume to work on each device.
PRESS 9 - 9 - 3
PRESS the VOLUME+ key, you will get two blinks.
Now The volume is set for all original devices.
menu
Clearing Out
A Device Key
PRESS 9 - 9 - 2
PRESS the device button twice. - Two blinks.
Any Button On The Remote
PRESS the button you want to clear - RELEASE
PRESS 9 - 9 - 4
PRESS the button you want to clear twice. - Two blinks.
All Key movers,Macro's, and Defaults
PRESS 9 - 8 - 0 -- Two blinks.
Scrambled Keypad
Sometimes it seems that the keypad is "scrambled". Functions like channels, volume, or numbers are not where they should be.
If your remote seems to be acting this way, try the following proceedure:
ENTER 9-7-3 (two blinks) (for URC-2005, try 9-7-4)
Try the functions on the remote
If the keypad continues to act "scrambled", you may:
Be on the wrong code for your device.
A wrong code may only operate a few functions of your equipment or they may be operating inaccurately.
Have something more serious wrong with the remote.
In either case you will have to contact us for more information.
menu
Key mover
An Advanced Function To A Button
PRESS 9 - 9 - 4.
PRESS the "MAGIC" button and then the three digit extended function.
PRESS the button you wish to use for that function - Two Blinks.
From One Button to Another
PRESS 9 - 9 - 4.
PRESS the DEVICE and the FROM button
PRESS the DEVICE and the TO button
Two Blinks
EXAMPLE: To take the volume from a TV and put it in the VCR mode,
it would be: MAGIC - 9 - 9 - 4 -TV - VOL UP - VCR- VOL UP - two blinks.
You would have to do the same process for VOL DN and MUTE.
"Shifted" Key Mover
In order to stack a second function on a key; when pressing the button you want the function on in the sequence, instead hit MAGIC and then the button you want.
To use the function: TAP the MAGIC button and release, then TAP the key you chose.
FOR EXAMPLE:VCR-MAGIC(hold 2 blinks) 9-9-4 MAGIC 2-3-4 MAGIC PLAY
If you hit the PLAY button - the VCR will PLAY, if you hit MAGIC -PLAY it will bring up a display.
menu
PRESS 9 - 9 - 6
PRESS the channel to be stored, up to 3 digits
PRESS the ENTER button
REPEAT steps 4 & 5 up to ten channels
If you do not store ten channels, you have to hold "Magic" for four seconds to close Favorite Cannel programming.
NOTE: To stop scanning, press any other button on the remote control.
menu
Macro-Sequence
This will allow you do do several functions with just the touch of ONE key.
PRESS 9 - 9 - 5
PRESS the key you want the Macro to be on
PRESS the sequence of keys you want the remote to do
PRESS "MAGIC" and wait for two blinks - RELEASE.
When you hit the key you put the macro on it will automatically start the sequence.
IMPORTANT: The Macro key will be the macro in ALL MODES so it is best to pick a key you will not need for anything else in any other mode.
menu
All Material Copyright Universal Electronics Inc.
"One For All" copyright Universal Electronics Inc.
Any questions about the products should be directed to help(at)ueic.com
Apr 03, 2013 | Televison & Video
Pushed reset button and will not respond. Red on light stays on
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
Nov 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
When I try to turn my flash on it says macro mode, What is this and how do I fix it?
Macro mode is for taking pictures of subjects very close to the camera. In this mode the flash is disabled.
Without knowing the model of your Digital Concepts camera I can't tell you how to take it out of macro mode. If there's a button on the back marked with a flower icon, press it. Otherwise look in the menu.
Jul 25, 2012 | Digital Concepts Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
When i try to turn my flash on it says Macro Mode
You're in macro mode and the flash won't function. Check your manual to find out how to get out of macro mode. Most cameras have a button or a dial with a picture of a flower representing macro mode. Find that and change it.
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Side buttons not functioning
Call your local Nikon Authorized Service Center,
there are two located in Florida, not sure where you are. Or call Nikon at 800-645-6678
Apr 15, 2009 | Nikon Coolpix 5700 Digital Camera
Can't turn the flash off
Hi The product you have given has Built-in flash with Auto, Forced on, Red-eye on, and forced off (Red-eye reduction On or Off).
There is a 1 1/8" diameter lens with a built-in lens cover that automatically opens and closes when the on/off button is pressed. Above the lens is the viewfinder window, flash and tiny (almost unnoticeable) microphone. There is also a small circle that has three functions: the autofocus assist beam, red-eye reduction lamp, self-timer lamp. A wrist strap comes with the camera and attaches through a slot on the front of the camera near the side.
To the right of those buttons is the four-way controller, used for menu navigation as well as:
  • Up - Metering (Evaluative, center-weighted, spot)
  • Down - Drive (Single-shot, continuous, self-timer)
  • Left - Focus (Auto, macro, infinity)
  • Right - Flash (Auto w/redeye reduction, auto, flash on w/redeye reduction, flash on, flash off)
Dec 28, 2008 | Canon PowerShot A400 Digital Camera
Use of macro digital feature
hi,let me just inform u that the macro mode is only for outdoors.So on the side of the camera u will find a sliding switch.Just slide it to the opposite direction to turn off the macro mode.Since u wanted to take pictures of jewelry pieces,turn on the flash if u have one and then take a closeup shot with good lighting conditions.If its too bright then use only the flash,if u r not satisfied with the quality then use only lights and then take a pic.Still face any prob plz get back to me.
Sep 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Settings affected
The functions accessed from the arrow pad—Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (up arrow key), Macro and Super Macro Modes for close-up photos (right arrow key)—will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ. Settings such as language, date and time, and sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Nikon S8100 Digital Camera Logo
13 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
