Question about Danby DDR2506 Dehumidifier
What is p1 error on honeywell hdh131 dehumidifier?
2 Suggested Answers
  • 3 Answers
SOURCE: P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Posted on Apr 06, 2010
What is wrong with a Westpointe dehumidifier when it stops removing water and displays P1? It will run this way for hours and kick in and work briefly once in a while on continuous.
Usually the P1 error indicates that dehumidifier needs to be defrosted. The unit has detected ice build-up on the condenser coils.
Unplug the dehumidifier for several hours. Then plug it back in. If the problem recurs, check that the fan that blows air across the coils is working properly. Make sure that the room is not colder than the operating range of the dehumidifier. If the problems continues to occur, you may have a refrigerant leak in the system. That will require a service call to repair the dehumidifier.
If the unit is under warranty, contact Westpointe. The manual I have for a Westpointe 65 PT dehumidifier, https://www.appliancefactoryparts.com/content/pdfs/136333-1.pdf, indicates the unit is covered through year 5 after purchase for a refrigerant system. For Warranty service, the contact point is Midea Consumer Service at 1-866-646-4332. If the unit is not under warranty, consider whether to replace the dehumidifier.
I hope this helps.
(I have seen a dehumidifier develop a refrigerant leak. It constantly froze before the leak was repaired and the refrigerant topped off.)
May 15, 2017 | Dehumidifiers
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
Jul 26, 2015 | Dehumidifiers
What does P1 mean
t appears to mean "defrosting." In other words, the condenser coils have gotten too cold and are icing up..
The filter is probably full, or the thermostat is faulty. Open it up and clean the filter first.
Sep 17, 2012 | Midea MDF1-30AEN3-BA4 WP 30PT ES...
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
P1 error code
Sep 13, 2008 | Danby DDR2506 Dehumidifier
P1 and P2 error codes
E2 = Not draining
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Danby DDR2506 Dehumidifier Logo
114 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
