Question about Hayden-Harnett 2002-2005 Honda CRV Engine Cooling Fan Hayden 02-05 Honda Engine Cooling Fan 2004 2003
What does it take to remove moisture from a right side 2004 honda crv headlight?
This is cutting down on efficnecy of the head light
    New Friend:
  • 44 Answers
Take the bulb out get a wire hanger tape a piece of cloth on it make it small to fit through the hole wipe it out and replace the bulb
Posted on May 14, 2014
    Master:
  • 697 Answers
If you can remove the headlight and if there is access to the interior (by removing the bulb or drilling a hole if it's plastic), put the headlight on the car dashboard in bright hot sunshine to evaporate all the water, or bake it in an over for 4 hrs at 90 Celsius or 190 F.
Then insert bulb and seal all openings with a this film of silicone sealant.
How do I remove moisture from a 2004 Honda CRV's right headlight?
The proper way will be to dismantle the headlight and reseal it again with three bond or sealant . The easy way will be to remove your globe and use low pressure air to blow into the port. Takes a while but its the easy way.
May 14, 2014 | Honda Cars & Trucks
Honda 2005 CRV - The left headlight is OK. The turn signal works both sides till I turn on the headlights. Then the right one does not work. that is a Honda safety feature. Non working turn signal on full...
Bypass head light switch and see what you get. Three items can cause your problem . The head light switch, flasher relay , shorts in circuit. I would go with switch.
Aug 18, 2010 | 2005 Honda CR-V
Removing a 03 crv headlight assembly
After much research, and little info on "how-to", I replaced both stock 9006 low-beam bulbs on my 2004 Accord. Despite much info on removing fenderwell splash shields, I was able to open the hood, and reach the passenger side harness, remove plug, twist and remove bulb and reinstall- no problem. Driver's side required removing the battery, but same procedure. No problems, no cuts or bruises. Owners manual is unclear, Hayes 2003-05 Honda Accord repair manual is wrong, and the dealer charges $29.95 per bulb installed. Took me 10 minutes. Tried to save the radio settings with a 9V battery in the power plug (memory-saver) but that didn't work."
Good luck.
Oct 16, 2009 | 2003 Honda Pilot
Headlight unit removal from a honda crv
You can do it alone, just remove the bumper, there should be a bolt and nut there and somewhere near the fender. The lamp will be free then.
Jan 11, 2018 | 2003 Honda CR-V
Low beam on either side last only a few months before needing replacement
I had the same problem with my 2005 CR-V starting about a year after I had the car (I guess the factory lights died), I started having to replace the bulbs every month or so. Very annoying. Never had both die at the same time, but often had one go out within days of replacing the other. It seemed to happen right at the start-up (I face a wall when I park, and could actually see the light "pop"). And Honda doesn't make it easy to replace these bulbs. About four months ago, I replaced both lowbeams, but I was particularly careful to (1) not touch the bulb with my fingers or against any of the engine compartment components. I was also very careful to reseat the rubber seal so that it was right side up (see the manual). Since then, I have not had the problem. I suspect that moisture was getting inside the seal and causing the bulb to pop (I had some bulbs completely blow out) or overheat. This probably goes back to my initial faulty replacement step where I didn't pay attention to making sure the rubber seal was right side up. All this being said, I suspect I'll start my car tomorrow and all the head lights will go out. And by the way, the high beams are the original bulbs. Go figure.
May 11, 2009 | 2005 Honda CR-V
2004 chevy impala no headlights
there's a button on the right side of the steering wheel that says serv push that button. It's put right there for when they use them as police cars you can cut the headlights off. You will probably notice that dash lights are on.
Jan 15, 2009 | 2004 Chevrolet Impala
How to change the whole headlight assembly on a 05 Honda CRV
You have to remove the front bumper and grill etc
There are 5 bolts holding the headlight assembly in place. 2 at the top and 3 underneath.
Remove the plastic cross piece by prising out the clips and then the grille clips too then unbolt the bolts eithr side under the wheel arch. The bumper is still fastened using cips. Pull the bumper forward to unclip.
Dec 23, 2008 | 2005 Honda CR-V
Hayden-Harnett 2002-2005 Honda CRV Engine Cooling Fan Hayden 02-05 Honda Engine Cooling Fan 2004 2003 Logo
151 people viewed this question
Top Hayden-Harnett Computers & Internet Experts
ray gallant
RSole
Are you a Hayden-Harnett Computer and Internet Expert? Answer questions, earn points and help others
